Storage No volume label
Discussion in 'Tech Support' started by Ryu_ookami, 19 Nov 2011.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    I've just finished putting together a new Pc for the GF went to go check the HDD's both are showing up as fine in the Bios. However under windows explorer the Sata drive isn't showing up.
    So I went to device manager and it says that the drive is working properly
    So I went to Computer Management and the drive is listed as being;
    Healthy (Primary Partition)
    Layout - Simple
    Type - Basic
    File System is blank
    but it has no volume label if I right click it all options are greyed out except Delete Volume.
    Here's the problem normally I would just delete the volume and recreate the partition etc but this drive has information on it that I HAVE TO RECOVER.
    Does anyone know a way of forcing Windows 7 to assign it a label remembering I can't just change the drive letter as A. it doesn't have one and B. the options greyed out.
    System is using Windows 7 - Fresh install as of less than 12 hours ago - fully updated
    Any help at all would be appreciated guys as I'm stuck as what to do next.
    (Not sure if it helps but I do have access to another Pc if I need it so I can change the drive to a new machine. I just don't want to do it if its not going to help. Second PC is running Windows XP SP3)
    EDIT 1: if I tell computer management to view the disk list the sata drive is showing up as an IDE drive for some reason.
    EDIT 2: I went into the bios and changed the drive setting to ACHI and when it booted into windows it started installing sata drivers etc then said the device was ready to use but it still hasn't assigned it a drive letter and all the options except delete volume are still greyed out.
  2. adidan
    25 Mar 2009
    Weird. Having a quick look about seems like this isn't actually that uncommon with Windows 7.
    After installing the drivers did you reboot?
    Edit: Is this the primary drive with W7 on?
  3. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I have had this problem a number of times and it seems to stem from the fact that the hard drive was formatted using a different file table to your current OS (i.e. from XP to 7).
    Try putting it in the XP machine, if that doesn't work then you should use some sort of recovery software but if it's just the partition table that is not readable (which is probably the case) then recovery should be quick and straightforward.
  4. Ryu_ookami
    11 Mar 2004
    no adidan, its a secondary drive the primary's fine and has nothing but the O/S on it the secondary however has about 12 months of files that I may (definitely did) have neglected to back up. by the way the GF says to say thanks again lol shes still cooing over the pretty blue motherboard lol
    the drive was formatted under XP so switching to Windows 7 may be the cause as MrWillyWonka said so I'll put it in the XP machine later and see if that does it when I get back later.
  5. adidan
    25 Mar 2009
    ^ good thinking.
    All versions of Windows have given me niggly problems in the past, if you can move the files over using it in a caddy or as a secondary drive would be a good idea.
    Starting from scratch with a format and install tends to be the only way to avoid most annoying problems.
  6. adidan
    25 Mar 2009
    Ah right.
    Yup, worth giving that ago, windows versions can be picky little buggers.
    Edit: Tell your GF I'm glad she's pleased. I prefer a black/red PCB myself :)
  7. adidan
    25 Mar 2009
    Did you have any joy getting to your files Ryu_ookami?
  8. Ryu_ookami
    11 Mar 2004
    I got side tracked doing something else so I haven't tried it yet but I'm sure it will be okay.
  9. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    One point on possible corrupt drives - do NOT try and write data to the drive (either by doing a quick-format or any other kind of write opetation).
    There is a possibility that you can recover data if the partition table has gone wonky, but any recovery software will scan sector-by-sector and look for begging/ends of files.
    Hopefully it'll show up on the XP machine (I do believe there are differences with the NTFS versions used by XP and Vista/7) but they should be backwards compatible.
  10. Ryu_ookami
    11 Mar 2004
    Ok, I just tried it and plugged the drive into the XP machine and its saying that Drive G: (the drive in question) is not formatted.
  11. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    You will have to run some recovery software to recover the data if both OS's are not seeing the partition.
    I use UFS Explorer
  12. MrWillyWonka
    25 Jul 2004
    One last option would be to run Ubuntu to see if it sees data, however this didn't work when I tried and easiest option now would be to run a recovery.
  13. adidan
    25 Mar 2009
    Actually asking a linux bod would be a good idea, I think there are a few things you can try to see if it can find the files but I've not touched the penquin for years. So to speak.
  14. lp rob1
    lp rob1 Modder
    14 Jun 2010
    +1 to this. Linux is very good at understanding the computer hardware - no matter what state it is in. Burn a live CD of Ubuntu, or put it on a memory stick (need to use software to make it bootable), then copy across the files. If Linux cannot pick it up, then it is likely that nothing will.
  15. PAULWARDEN
    PAULWARDEN What's a Dremel?
    25 Apr 2009
    You could also try Hirens boot disk has data recovery software included just download and burn to a cd or even usb key
