News Noctua Shows New CPU Coolers
Discussion in 'Article Discussion' started by Claave, 31 May 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    does the middle one hover?
  3. enciem
    enciem Minimodder
    23 Sep 2009
    It does if not attached to a computer
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I say it'd hover, even if attached to a computer, with a set of Gentle Typhoons on there.
    Anyway: One on the far right takes my interest. Be curious to see if it'll outperform a ThermalTake Frio.
  5. lp1988
    lp1988 Minimodder
    24 Jun 2008
    More area is not always a good thing, remember that it will drive the price up, and as the most vital part is the transfer from the CPU into the heatpipes it may not even give an advantage worth mentioning.
  6. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    From what I remember Noctua are pretty good at making decent coolers, but I think lp1988 hit the nail on the head with price; Noctua aren't known for making anything cheap.
  7. GoodBytes
    20 Jan 2007
    I think this is for the new Intel CPU where the RAM in on the both side of the CPU.
  8. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Can I put in a request for photos alongside articles that we can click to biggerfy (that's not a word but I don't care)? I'd like to see these a bit more close up.
  9. bagman
    bagman Minimodder
    18 Apr 2009
    they look pretty damn wired very interested at how they stack up against the king of air cooling atm, the NH-D14
  10. Smasherbasher
    Smasherbasher What's a Dremel?
    1 Jun 2011
    Jesus. Those are massive. Going to have to design some custom mounts for them.
  11. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    It'll be interesting to see how the middle one fits in with the air flow of modern case designs. Will the lack of straight line air flow harm performance?
  12. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    also noctua showcased a prototype LGA 2011 backplate stuff for the Noctua fans... does it mean that the current generation of coolers meant for the LGA 1366 socket would not fit on the LGA 2011 boards?
  13. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    Oh look, one they already make, a Scythe Susanoo and a Coolermaster V8!
    Not much innovation this year.
  14. Taffy
    Taffy Folding for Margaret 17/3/2011 RIP
    23 Apr 2009
    Will the case manufacturers enlarge their Cases to allow us to fit these ?
  15. chris66
    chris66 Minimodder
    10 Jan 2011
    Why the hell are these things getting bigger (and ever uglier - subjectively), while the thermal properties of CPU's are becoming so efficient that you can overclock to 4.6GHz on a standard Intel cooler?
  16. RedFlames
    23 Apr 2009
    LGA2011 uses a similar cooler mounting to the dual-socket 1366 boards [the cooler screws into the socket essentially]
  17. l3v1ck
    23 Apr 2009
    In theory larger fans can move more air at lower speeds which means less noise. Though looking at the photo's I think you're right to assume these are designed for cooling over noise. So Your question is valid ;)
    Do they know something we don't? Are 2011 CPU's going to be so monsterishly huge that require high cooling capacity? I doubt it myself. I'm sure they'll need more than 1155 chips, but not that much more.
  18. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    no but it makes your pc 20% lighter, lol
  19. GoodBytes
    20 Jan 2007
    Only when it's turned on :)
    I vote for gravity isometric plates, powered by an antimather mather field generators. It works by creating an asymmetrical subspace patterns with the help of a verteron quantum matrix, to make an inverted spacial actuator, which makes the computer 30 to 40% lighter, when the system is turn on or off. It works all the time due to generator. Oh, most importantly, to transfer the power, it uses a photonic tertryon network system.
    It could be improved with a buffered modulated databanks nutation using a rapid pulse phased frequency harmonics system.
    Quick simple, really. Shouldn't be tooo expensive to make.
  20. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
Tags: Add Tags
