Cooling Nofan CR-80EH
Discussion in 'Hardware' started by Ice Tea, 23 Jun 2018.
  1. Ice Tea
    Ice Tea Minimodder
    26 Jul 2009
    Nofan CR-80EH passive cooler
    Anyone running one as the reviews are very mixed?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Had one of these on an AM1 CPU. Actually posted a thread right here...
    https://forums.bit-tech.net/index.p...ini-itx-pc-now-with-pics.278711/#post-3688081
    Worked very capably for three years. The only reason I decommissioned it was because of a burnt out component on the motherboard...
    https://forums.bit-tech.net/index.php?threads/something-fell-off-my-motherboard.339197/#post-4451426
    Otherwise the CPU cooling worked just fine. I would say the only thing to be wary is the Motherboard and RAM. If you're aiming for a passive design then both these components need ventilation and heatspreaders to deal with any hot componenets such as VRM. Just something to keep in mind!
    Ice Tea likes this.
  3. Ice Tea
    Ice Tea Minimodder
    26 Jul 2009
    Cheers Buddy , Currently running a HR-02 passive but it's heavy on the socket and the NoFan is a 1/3rd of the weight.
  4. Blogins
    3 Aug 2010
    Something else worth mentioning is that I found the mounting brackets adaptable. It's not supposed to work with AM1 motherboards but by pivoting the CR-80EH bracket instead of fixing it with two screws makes it very easy to attach to the CPU. Just need enough room to manoeuvre around the CPU!
  5. Ice Tea
    Ice Tea Minimodder
    26 Jul 2009
    What cooler did you replace it with?
  6. Blogins
    3 Aug 2010
    I didn't! Started using a different rig entirely. Went 3770K with GTX 1070, so far from passive! :thumb:
  7. Ice Tea
    Ice Tea Minimodder
    26 Jul 2009
    LOL , thanks :)
