Case Mod - In Progress Noir - by marius_mym
Discussion in 'Project Logs' started by marius_mym, 18 Nov 2012.
  1. marius_mym
    marius_mym What's a Dremel?
    5 Dec 2010
    Hello guys, I'm Marius and I'm from Romania.
    I'm a member of this community for almost 2 years, but I didn't have the guts (until now) to post my previous projects. This is my current project, I started this project because I had some hardware components from my previous rig.
    I already made an ITX case, and also a full tower case, so this time I decided to base my project on a micro tower case.
    The name of the project represents, as you already figured out, the main color of the build.
    I wanted a stylish case, but I didn't have enough money for a Lian Li so I bought a Fractal Design Core 1000, and also a mATX motherboard
    (I sold my previous motherboard because it was ATX form factor).
    After I took the photo above, I "strip" the case to do some measurements.
    I already knew that I want to install two 120mm fans in the front panel of the case (maybe for a water block sometime). In order to do that I had to cut the original face of the case chassis, and build a new one.
    After I finished the front piece I cut a second piece of aluminum to "extend" the motherboard tray, then I took the pieces, plus some hardware parts and I painted them.
    I used a thermo resistant paint because is more resistant that the normal one and also you don't have to apply primer or lacquer. The disadvantage of this paint is that you have to heat the painted piece up to 160-200 C in order to obtain a full dry of the paint.
    Because I don't have an oven to dry the parts, I heat the pieces with my heat gun :D. For ram radiators I used a "normal" paint.
    The results are below :
    The next parts that received the "thermo resistant paint treatment" was the rear brackets of the case, the bracket of the GPU and the top cover of the PSU (because I scratched when I removed the stickers:wallbash:).
    When I finished with the painting I took the left panel and cut a hole for a windows. I cut the acrylic piece and I sanded the edges to obtain that "frozen" effect. The windows looks good but I'm not 100% happy with it and I think I'll change the acrylic piece with a dark one (to fit better with the theme of the project).
    The next step was the sleeving job, but before anything else I would like to thank to sleeve-modding.com for sponsoring my project.
    After I received the package I started to sleeve the front panel connectors, and then the PSU.
    I wasn't happy with the long and useless (for me) cables of the PSU so I decided to short some cables, and get rid of other and make my power supply semi-modular:D.
    Because the space inside my VX450 was very tight I was forced to mount the connectors for modular cables outside of the PSU. Overall I'm pretty happy with the results:).
    And some garbage:lol: :
    After I finished the work with the PSU I started to work at the front panel. I didn't like the original metallic mesh of the case so I asked a friend to help me with a piece of black (matt) acrylic in order to replace the metallic mesh.
    The shapes were cut with a laser, because I was afraid no to damage the acrylic.
    This is the current state of the project, I'll make an update as soon as I manage to do some progress.
    Hope you like my little project !
    P.S.: My english isn't perfect, but i did my best :blush: !
    biojellywobbles likes this.
  2. Hanoken
    Hanoken O.O
    12 Jul 2012
    your English is fine :) understandable and clear ha ha ha, I love your black theme that you have going at the moment! can't wait to see what you have in store for this project and good luck !
  3. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    molex and sata cable? gone?
    well, i'll sit here and wait for your next update
  4. makarov7
    makarov7 What's a Dremel?
    9 Nov 2012
    Very cool side panel windows - frosty :brrr:
    Noir = black , it will be a dark build i think :D
  5. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    I think a tinted window would look great ;)
    Sent from my GT-I9100 using Tapatalk 2
  6. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    Wanted to see one of these modded for a while, gives me ideas on what to do with mine!
  7. jamsand
    jamsand Minimodder
    21 May 2011
    Fantastic finish on that paint work!
  8. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Great work so far, love the effect on the side window!
  9. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    looking promising =) Love the Ram photos
  10. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Comme une nuit noire. Me like it :)
  11. timerhan
    timerhan What's a Dremel?
    6 Nov 2012
    +1 :thumb:
    Very cool!!!
  12. marius_mym
    5 Dec 2010
    Woow, thanks for the kind words guys, I didn't expect to see so much replies in a such short time.
    Thanks:thumb: !
    Well, I had to get rid of those "tentacles", because they were useless:D. I only need one sata power connector (for HDD), and maybe another one for an SSD, but I'll make my own extensions:).
    I'm glad you like my side window guys ! I've been waiting for a long time to use that "effect" and this project offered me the perfect opportunity, because the window is pretty small and I can change it very quickly without wasting too much acrylic (in case that I don't like the way that looks:D).
    I agree with you:)! The tough part is to find a tinted acrylic window in Romania, but i'll do my best.
    Well, I hope that my project will give you some ideas :naughty:! I can't say that this case offers unlimited possibilities, but there are couple of things that you can change :).
    Thank you, sir :D ! I did my best, but the paint helped me a lot. The entire process (from the first layer of paint until full dry) took about 2 hours :cooldude:
    Thanks :thumb:! I love them too:lol: !
    Glad you like:) !
    P.S.:My french is even worse than my english, i had to use translate google to understand :blush::lol: !
  13. Parge
    16 Jul 2010
    So far, so awesome!
  14. KidMod-Southpaw
    28 Sep 2010
    Agreed! Not too keen on the window style though, takes away from the minimalism of the build.
    You're awesome with spraypaint though! Look like you've powdercoated everything! :thumb:
  15. marius_mym
    5 Dec 2010
    Thank you Parge:)!
    Totally agree with you:thumb:! Even if the window looks fine, it doesn't fit 100% in project. I'm going to change it as soon as I find a tinted acrylic sheet.
    I'm glad you like my spraypaint:D !
    On the other hand today I made some kind of "splitter" to power on a stripe of LEDs and also a fan controller.
    I choose to power on the fan controller with a 2 pin connector because in this way i can reduce the number of cables (I'm going to use 26 awg wire and only one sleeving wire for both cables of the fan controller).
  16. marius_mym
    5 Dec 2010
    Last time I show you the splitter that I'm going to use to power the fan controller and a LED stripe. In the previous weekend I made a cable to connect that splitter to the power supply:p.
    After I finish the cable I made a backplate for the GPU :D. I know, is pretty simple, but I like that "clean" look.
    Ohh, I almost forgot, today I receive a small package form my sponsor sleeve-modding.com.
    I'll use a part of these items to build the fan controller.
    The other part (the rubber grommets and the switch) I took it "just in case" :D :hehe:.
    P.S.
    : I'm still searching for that tinted acrylic :worried: !
  17. KidMod-Southpaw
    28 Sep 2010
    More great stuff!
    By the way, what I meant about the windows was that the smudged style border doesn't work. The actual clear plastic is fine and probably better. :thumb:
  18. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    that window! Mind = Blown!
  19. marius_mym
    5 Dec 2010
    Glad you like my little update !
    Regarding window panel... meh, it would be to easy to mount a clear acrylic :hehe: !
    Glad you like it mate :thumb:!
    It looks good indeed and also is easy to obtain (you only need a 300-400 grit sandpaper, a piece of acrylic and.... some imagination :D) but unfortunately it doesn't fit perfectly into the project:duh:.
  20. marius_mym
    5 Dec 2010
    Hello guys !
    I know is been a while since my last update, but i didn't have anything "cool" to show.
    As I said before i wanted to made a different type of fan controller for this project, so i asked a friend to help me (i'm not very good with the solder gun) and this is what we manage to do :
    The "fan controller" has 3 positions : 12V=>off=>7V.
    After I mounted the fan controller, I also mounted the cpu cooler and i manage to do some photos :D.
    Unfortunately i still need an SSD , but the good thing is that the lack of the SSD didn't affect the "design" of the interior, because the SSD will be placed under the GPU card, and as you can see the Sata power cable for the SSD is already in place:thumb:.
    So... enjoy the photos ! Hope you like :blush: !
    After i did the photos i realized that i don't like that "code" from the fan of the cpu cooler, so i rotated the fan by 90 degrees :D, and I made some "indoor photos", because outside is veeeery cold :D.
    Hope you like it guys :thumb: !
