Modding Noise Absorption Mod?
Discussion in 'Modding' started by mvx, 12 Oct 2005.
  1. mvx
    mvx What's a Dremel?
    4 Feb 2005
    Anyone know or have any ideas on a cheap mod to make noise absorption pads or just to make your pc quieter. Thank you.
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    that stuff that comes in the bottom of motherboard boxes, ive used that before to absorb a little bit of noise
  3. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Egg crate foam is pretty decent. According to this page, rubberized carpet foam (NOT the chunky foam stuff that falls apart) is very good for dampening noise. I've yet to try it.
  4. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    I made my own with cork board, glue and rubber pads.
  5. mattthegamer463
    26 Nov 2004
    i would use some sponge sheets if you can get that, it works well, the sponges absorb the sound.
