Noisy fan replacement query.
Discussion in 'ASUS' started by Yadda, 31 Oct 2011.
  1. Yadda
    Yadda Minimodder
    25 Jul 2003
    Hi, I have a pair of Asus HD 5770 1GB cards with the V2 egg-shaped cooler (EAH5770/2DIS/1GD5/V2/A) and one of the fans has started making an annoying noise for a few minutes each time I start-up the PC.
    As far as I can see, each fan can be easily removed from its heat sink by removing 3 small screws whilst leaving the heatsink in situ. Is it was possibly to buy 2 new fans (without the heatsinks!) to replace my tired ones.
    Many thanks.
  2. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    You can do this.
    Try taking the fan off and google the part number.
    You will either find you can buy a exact replacement or get the spec and buy another fan that's up to the job.
  3. Yadda
    Yadda Minimodder
    25 Jul 2003
    Thanks. If I don't get anywhere with Asus support then I'll look into other options.
  4. Yadda
    Yadda Minimodder
    25 Jul 2003
    Looks like I'll be exploring other options. :)
    That's a shame, I expected better from Asus - do they still monitor this forum?
  5. Guest-16
    Guest-16 Guest
    It's not possible to buy the fans alone from us sorry. If it becomes a serious issue you'll have to RMA it.
  6. Yadda
    Yadda Minimodder
    25 Jul 2003
    I'm reluctant to RMA for such a minor fault so I'll look out for a replacement fan elsewhere. Thanks for the response.
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    If you're not going the RMA route I'm curious if a dab of fine machine oil would alleviate the noise somewhat. I did the same with a DELL D630 laptop fan and it helped smooth over the noise.
  8. Teelzebub
    27 Nov 2009
    Wont that void the warranty? I would RMA it myself
  9. Yadda
    Yadda Minimodder
    25 Jul 2003
    Technically I suppose it will invalidate the warranty but I can always put the original fan back if needed at a later date. It's just a fan that very easily detaches from the heat-sink by 3 easily accessible screws. I'd far rather replace it myself than send the whole card away, risking all kinds of complications.
    I'll give this a try, cheers.
