Other Noisy PC - first step Case or Power Supply?
Discussion in 'Hardware' started by GilesM, 24 Jan 2011.
  1. murraynt
    murraynt Modder
    6 Jun 2009
    That's what you should do but not many do.
    I just touch a tap or something to ground my self then start ripping on a normal table with a towel underneath to stop any scratches.
  2. russell16688
    russell16688 What's a Dremel?
    23 Jan 2011
    I found that having quite a small room that gets warm having a large case (even if you havent got a huge mobo and lots on it) plus some big slow spinning fans keeps the pc cool and fairly quiet.
    I also put mine on the floor so the fan noise wasnt at head height.
  3. GilesM
    GilesM What's a Dremel?
    24 Jan 2011
    So, my Fractal Design R3 case arrived today.
    Prior to doing anything I have studied all the connections on the existing set up, worked out where they all go and then examined the new case. It's very nice, but i noticed at the back top left as you look at the back, next to the fan... a great big opening!
    I rang Scan Computers (who I bought it from) and they said... "it's meant to be like that".
    Not wishing to doubt the good guys at scan, I went to Fractals web site and sure enough, in the photo's there is is a big rectangular hole.
    How can this be a noise reducing case with a big hole in it? Or am I wrong?
    Since the product is as shipped, I will go ahead and fit it. It's a lovely bit of engineering (apart from the hole)..
  4. GoodBytes
    20 Jan 2007
    I don't really undertsand what are you talking about. A picture might help.
    The case has a variety of holes for fans to get some air flow going to cool off your components, else it will be an oven in a mater of minutes, and at the inside (once the panel are removes) for cable management.
  5. GilesM
    24 Jan 2011
    well, the image is of the side view with the panels open, but I am talking about the back view, right next to the fan there is a rectangular section that is open to the world.
    LEt me see if I can get a picture of it and post...
  6. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    That's where your motherboard's IO shield plate goes.
  7. GilesM
    24 Jan 2011
    So, here is a picture of the back of the case...[​IMG]
  8. GilesM
    24 Jan 2011
    OMG!
    DragunovHUN you are right.. what an arse I am.
    Can you tell I have not done this before!
    What a prize plonker I HAVE BEEN... so sorry all...
    I hope it gave you a laugh anyway...:duh:
  9. wyx087
    15 Aug 2007
    for silent disks, you should be looking at SSD's. they offer both speed improvement over your current HDD, and totally silent operation.
    a 40GB SSD is pretty cheap, and should allow you to get most of often used programs on there. then use your current HDD for data storage such as stuff inside "My Documents"
  10. GoodBytes
    20 Jan 2007
    Ok, let me explain.
    Here is an example of a motherboard backplate (it can be different)
    The backplate can be difficult to remove and install.. it's one of those ultra tight fit things that needs to be inserted. Take your time.
  11. GilesM
    24 Jan 2011
    yes, the SSD's might be a good idea, but there are more fundamental things to do first, this weekend, new case (ahem).. then move the OS to a new SATA drive (to eliminate the clunky old IDE drive)
    then perhaps a new PSU.
    That's my schedule of activity for now... but you are right about the SSD's perhaps I can tag that on to the end of the list.
  12. GoodBytes
    20 Jan 2007
    If you have an HDD and SSD, it won't reduce system noise, as the HDD will still spin.
    They are quieter HDD's around. But the case does help greatly in reducing noise.
    If you are going with an SSD, get a 120GB one, where you nicely fit Windows, the coming up service packs, updated, room for program temps, software, and save large project which you want to open quickly. If you need more room, get an external HDD enclosure on eSATA, and use your old HDD. Turn on the external HDD when needed.
  13. GilesM
    24 Jan 2011
    So, I moved the PC into the new case, and horror! the PSU connection to the motherboard would not reach, about 4 inches too short!
    So, new PSU, went for a new PSU, Corsair CX600 (I think).
    Put the whole lot in the new case and my word, what a difference!
    Now I can hardly tell it's even on!
    With the help of all of you, my goal has been achieved.
    Thank you all.
  14. GoodBytes
    20 Jan 2007
    AWESOME!
    Glad we could help.
    Yea, if you go with a good PSU manufacture. They tend to well test their units to ensure that you don't fall onto a short wire with special cases.
  15. specofdust
    specofdust Banned
    26 Feb 2005
    I know the OP's problem is basically solved, but since it's such a useful resource I might as well link everyone to http://www.silentpcreview.com/ - damn good site for silent PC kit reviews.
