Electronics Nokia LCD - Picture and wiring details inside
Discussion in 'Modding' started by g0th, 13 Apr 2005.
  1. g0th
    g0th What's a Dremel?
    12 Apr 2005
    As you can see, it can be interfaced with minimum components, no fancy level converter IC's or anything. And no external power supply - nice!
    The resistors etc can be soldered to the pins of the D25 plug, easy!
  2. coorz
    coorz Miffed
    25 Apr 2003
    Nice, and what software do you use to drive it?
  3. g0th
    12 Apr 2005
    LCDInfo.
  4. chopsuwe
    chopsuwe What's a Dremel?
    9 Jul 2002
    Sweet! Ok, I'm off to pinch my brother's dead 3310 now...
  5. coorz
    coorz Miffed
    25 Apr 2003
    :D :thumb: thought so. Hope you'll post it over there too :)
  6. g0th
    12 Apr 2005
    Note that the 3315 LCD is actually what i used for this mod, it's essentially identical to the 3310, with 8 metal pins.
    I think the 5110 and similar use a similar interface (not the same pinout but close), but they're a little trickier to do as they have the conductive rubber bit connecting it to the PCB, not just nice pins ready to solder.
    The 3315 one doesn't have a backlight, but the reflective layer is very thin, it lets a lot of light through so it's easy to backlight with a bright light behind it.
  7. Gomi no Sensei
    Gomi no Sensei What's a Dremel?
    21 Apr 2005
    Hey Guys, I've had a 3310 LCD running on my PC parallel port for a while now and it's easier than you think, this SW uses a much simpler circuit and is a LOT more eye candy than LCDInfo. Just look at this page for details: LCDHype Nokia 3310 I even got an old Nokia 5110 LCD working using this SW, it ROCKS ! :rock:
  8. TTmodder
    TTmodder Hammertime
    9 Apr 2005
