News Non-ConDUCKtive Fluid at PimpRig
Discussion in 'Article Discussion' started by GreatOldOne, 24 Jun 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    An intersting article from PimpRig - which details the preliminary testing of a non conductive oil, which will eventually be used in an actively cooled system:
    "It all started with Gabriel, the Gaming Program Manager from Intel challenging me to make a great mod for a computer. He never expected this. The precursor for the "ORB""
    More here
    [Homer]
    "I find your theory intriguing, and wish to subscribe to your news letter....
    [/Homer]
    One to keep an eye, methinks.... :D
  2. Guest-16
    Guest-16 Guest
    The problem with "non conductive oils used for active cooling" is that they are expensive and if they are "direct contact" jobbies VERY messy. Water is cheap with a good heat capacity and if pure non conductive (ok, itll never be *pure* i know).
  3. GreatOldOne
    29 Jan 2002
    But the article states:
    He doesn't state what the fluid is (apart from the fact that it's oil based), but you can infer from the article that it's a hell of a lot cheaper than HFE (or he wouldn't be using it).
  4. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    I found a supplier of a certain fluid used in transformer cooling - UK based and cost was approx £80 for a 5 litre drum - never found the time to do that project - but may have stuff/url about if anyone wants it
    Ooops was 25 litres IIRC :(
  5. ravenlot
    ravenlot What's a Dremel?
    24 Jun 2003
    I can't remember the web page but I saw another similar experiment. The person didn't want to use the expensive stuff either. If I remember correctly, he used mineral oil and worked very well. Perhaps the author read the same article.
Tags: Add Tags
