Motherboards Non-posting, no LED Gene-Z
Discussion in 'Hardware' started by ModSquid, 21 Jan 2014.
  1. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Just a quickie chaps - I've been rebuilding my system and have been carting the motherboard (Maximus IV Gene-Z) about to test fit and now I've brought it back upstairs and hooked it up to the system again, it won't POST (typically) so I've probably knackered it but am hoping not.
    It has lights on on the power and reset buttons and everything spins up - cooler, graphics etc. - but the disk is an SSD so obviously I can't tell if it's accessing or not. Regardless of that, though, the board should still POST, but there is no life in the readout code LEDs.
    I've removed all screws and tried to reset the BIOS using the button on the back, but still no joy. I've tried to be careful when handling it too, but obviously something has gone awry. I'm expecting the worst, but maybe there's a fix...grateful for any useful suggestions!
    Cheers,
    Ed
  2. TheMadDutchDude
    23 Aug 2013
    Does it even turn on, as in do the fans spin and does it stay powered up?
  3. ModSquid
    16 Apr 2011
    I've only got the cooler (Kuhler 620), graphics card and the SSD attached at the moment, but yes - the cooler fan and the GPU fan both spin up and stay on and the board stays on/powered, but no POST.
    The board is definitely powered as there's a light by one of the SATA ports that stays lit continuously. I've noticed it flickering before when the SSD is sending data, but this time around it's just continuous.
    I've tried pulling the GPU to see if it made a difference, but still nothing.
  4. jinq-sea
    15 Oct 2012
    Have you a different GPU to try? There's no onboard graphics output on the Gene-Z is there?
    Otherwise pull the BIOS battery and leave it for a bit? CPU seated OK?
  5. mrbungle
    20 Sep 2004
    has HDMI, could try that
  6. TheMadDutchDude
    23 Aug 2013
    Sounds like there's no power to the CPU to me.
    ModSquid likes this.
  7. jinq-sea
    15 Oct 2012
    Ah - my Extreme-Z has no onboard vid out IIRC haha
  8. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I would reseat everything and remove the battery from the board for around 30 minutes or so to allow the CMOS to properly clear. The onboard video will only work if you are using a chip which has built in VGA.
    Also as suggested check your PSU connections.
  9. ModSquid
    16 Apr 2011
    Right - we got there, guys! Thanks for chipping in with the suggestions - :duh: bit embarrassing, really, but it turns out it was the constant up/down the stairs and the reconnecting cables in a rush that was to blame. That, plus the fact that I was so convinced I'd knackered it!
    Constantly moving the GPU about had unseated the power cable to the CPU, so no juice going to it. Combined with the new riser I was testing out (30cm powered), I was getting a mixed bag of errors where no video would come out of the digital ports on the card, just the VGA.
    Got rid of the riser and seated the CPU power lead correctly and we're back in business. Thanks to all for the advice and a humble +rep to Dutch since he nailed it early doors...
    Appreciated and lesson learned :nono:
