Build Advice noob compatability
Discussion in 'Hardware' started by davis99, 25 Jan 2012.
  1. davis99
    davis99 What's a Dremel?
    24 Jan 2012
    hi everyone
    i am very new to this and have put together a list of parts. could you guys just take a look and see if this will all work together? also pls feel free to add any advice regarding psu, how big will i need and will it have enough connections to power the fans in the case???
    Case
    NZXT Tempest - http://www.play.com/PC/PCs/4-/13346...tml?_$ja=tsid:11518|cat:13346368|prd:13346368
    CPU
    Intel Core i7 2700K Unlocked (4 x 3.5 GHz) 8MB - http://www.advancetec.co.uk/acatalo...Quad-Core-8MB-Cache-BX80623I72700K.html#a0985
    CPU Heatsink
    Arctic Cooling Freezer 13 http://www.play.com/PC/PCs/4-/20934...tml?_$ja=tsid:11518|cat:20934052|prd:20934052
    Memory
    Corsair Vengeance 16GB (4x4GB) Dual Channel Memory Kit PC3-12800 1600MHz DDR3 DIMM
    http://www.kikatek.com/product_info.php?products_id=187522&source=froogle
    Graphics Card
    NVIDIA GeForce GTX 550 Ti - 2 GB - (EVGA) (PCI-E)
    http://www.amazon.co.uk/dp/B0050ICB...de=asn&creative=22206&creativeASIN=B0050ICBAO
    Motherboard
    Asus P8P67 LE (Intel P67) - http://www.awd-it.co.uk/asus-p8h67-rev-3.0-intel-h67-ddr3-atx-crossfire-motherboard-lga-1155.html
    Sound Card
    Creative Sound Blaster X-Fi Titanium HD (PCI-E)
    http://www.currys.co.uk/gbuk/creati...81d5-a25372d2e3d7&istItemId=pxtxarma&istBid=t
    Power Supply ??
    Hard Drive
    60GB OCZ Agility 3 SSD SATA-III, Read 525MB/s, Write 475MB/s - Silent - http://www.ilgs.co.uk/products.asp?partno=AGT3-25SAT3-60G
    Optical Drive
    LG (CH10LS20) 10x Blu-Ray Reader & 16x Dual Layer DVD +/- RW Writer - Black (SATA)
    http://www.advancetec.co.uk/acatalog/LG-CH10LS20-Blu-Ray-Reader-OEM.html#a2240
    Operating System Microsoft Windows 7 Ultimate 64 BIT (Genuine DVD & COA Included)
    http://www.aria.co.uk/SuperSpecials...ating+System+?productId=38276&source=googleps
    thanks guys
  2. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    What are you going to use this build for? Why do you have so much memory in it?
    As for PSU recommendations, 650W or so should be enough. See my guide here for PSU recommendations.
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I would change the gpu to a 560/560ti as the extra vram on the 550ti isn't doesn't make up for the actual gpu.
    I would also just get a i7 2600k and then overclock, this then means you could spend more in other areas.
    As for the psu, the antec TruePower 650w should be enough and its partially modular :)
  4. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Definitely get a beefier GPU, you will only regret it! Also save some cash and either get the i7 2600k or if your not going to be doing encoding/folding/rendering save even more and get i5-2500k!
    Also grab a decent PSU 650~700w should be plenty for that and make sure its from a decent brand name e.g. corsair etc
  5. Deders
    Deders Modder
    14 Nov 2010
    Won't need more than 550W for PSU, +1 on getting at least a 560, if not a 560TI.
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I wouldn't touch a Creative sound card with a bargepole if I could help it. Otherwise; it's about right. I'd suggest going for the 2600K. The 100mhz difference can easily be made up, and it's cheaper!
    Besides that; it all looks about set, a better GPU might be an idea, and possibly try and grab a spare HDD from an old PC for a bit of extra storage, but those aren't pressing concerns.
