Modding Noob question but i have to get the info somehow
Discussion in 'Modding' started by Ryu_ookami, 17 Mar 2004.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    first one hopefully is easy
    if I want to sleeve the power cables etc in my tower unit what do I need to get to actually put around the cables to sleeve them.
    second
    I plan on starting a mod where i build a new base unit from scratch using a load of metal and a mig welder (plz don't ask you really don't want to know) and i have been told that ide cables only work over a certain distance and that sata cables are better so the question is whats the difference and whats better (the case will be taller than a full tower by about half as much again)
  2. Go4t
    Go4t i
    13 Dec 2003
    for the cable sleeving :search:
  3. tk421
    tk421 Idiot.
    15 Jan 2002
    techflex. google it.
    ide max length - 1.5 ft
    sata max length - 3.3 ft
    has to do with sata being single device cabling vs. ide being 2 devices.
