Linux Noob question, problems with 4tb disk in ubuntu
Discussion in 'Tech Support' started by davie107, 16 Jan 2019.
  1. davie107
    davie107 Linux or Windows???
    18 Dec 2007
    Evening all,
    Recently I have invested in a 4tb hdd for my Plex server which currently runs on Ubuntu.
    Previously I have been using a 120gb ssd for the O/S and then 3 2tb hdds which are full of media and had been running seamlessly.
    I invested in a 4tb hdd as I have been running low on space and initially it seemed to work as a plug and play option, however it soon encountered errors and wasn't able to mount properly and generally didn't want to play ball.
    What is the best way to format the drive to be used as a storage drive, my other drives are in ext3/ext4. Is there a best way to set this up using terminal and have it auto mount on startup?
    Thanks in advance
    Dave
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    Was it formatted as NTFS? If so you may be having permissions issues.
    You can format it as EXT4 or XFS and it should be fine.
  3. davie107
    18 Dec 2007
    It was originally formatted as ext3 using the ubuntu disk tool however then refused to mount. i tried formatting on a windows pc, changed the disk from mbr to gpt and fromatted as ntfs however then had permission issues so deleted the volume. Currently the drive shows up in the disks utility with a 4tb volume in ext4 however when i try to mount I receive an error
    error mounting filesystem
    message recipient disconnected from message bus without replying (g-dbus-error-quark,4)
  4. Yaka
    Yaka Multimodder
    26 Jun 2005
    did you solve this issue?
    davie107 likes this.
  5. davie107
    18 Dec 2007
    Hi Yeah, had to reformat the drive and create partitions in the terminal and all seems to be working as it should now and mounting on boot.
    Yaka likes this.
