Noob Question
Discussion in 'Hardware' started by Strategy, 28 Mar 2006.
  1. Strategy
    Strategy Banned
    19 Jul 2005
    With a FX57, what divider & FSB would be used to theoretically achieve 3.8Ghz? Using any type of RAM. Have a blagger on msn who said he *had* a FX57 that he could clock up to 4ghz, but it wasn't stable, but was at 3.8ghz, when I asked him what FSB HTT & divider he used, he went offline.
    Is it even possible?
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Possible but highly improbable. It takes phase change cooling to bring them to those speeds, and they wont be stable then - even 3.4 probably wont be stable. The guy more than likely had a Pentium 4.
  3. Strategy
    Strategy Banned
    19 Jul 2005
    Said cooling was done via a Promethia, but ain't they damn expensive?
  4. RotoSequence
    6 Jan 2004
    Conventionally yes, they are rather expensive. Like I said, its doable, but not likely. You wouldnt have to change memory speeds if you adjust the multiplier as well.
  5. Strategy
    Strategy Banned
    19 Jul 2005
    So I can safely assume he's chatting fart?
  6. RotoSequence
    6 Jan 2004
    Relatively safely. Its likely he's pulling your leg, but there IS a chance he actually is running a phase changed cooled FX at the 3.X GHz range.
  7. Krikkit
    21 Jan 2003
    Proof that it can be done.
    Sounds like BS, but take it with a pinch of salt. It could always be true of course. :)
  8. Hans Voralberg
    Hans Voralberg New Member
    12 Mar 2005
    My m8 has a FX-57 and a LightSpeed, maxed out @ 3.2Ghz
