Cooling Noobie Water Boy!
Discussion in 'Hardware' started by richman, 7 Jan 2004.
  1. richman
    richman What's a Dremel?
    17 Sep 2003
    Hi all, iam thinking of going down the water cooling route on my new case (chieftek dragon) :D and was woundering if any of you could list all the things i would need and where i could get them (UK) i would be very greatful for this information.
    Cheers
    Richman
  2. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
  3. richman
    17 Sep 2003
    maybe someone can reccomend a kit for me :rock:
    cheers
    richman
  4. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
  5. richman
    17 Sep 2003
    thanx for that, i heave read it and loking for more information on watercooling but prob will use this kit. :rock:
    Cheers
    Richman
  6. orb
    orb satisfying.
    23 Dec 2003
    OO, that review is good, £203 for all the stuff you need, i might need to save
    will it work in a Chieftec Matrix?
  7. richman
    17 Sep 2003
    will it work in a chieftek dragon with a abit nf7-s
    cheers
    richman
  8. mushky
    mushky gimme snails
    24 Mar 2003
    You could make it work
  9. kiljoi
    13 Oct 2003
    that's what modders do, after all...
    :dremel:
  10. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Ok which route do you want to go down.
    Silence and piece of mind
    Or
    Power and extreme clocking
    The water chill kit is a good place to start its easy to set up and loads of ppl are getting on well with them. As there are many reviews available you'll have no trouble setting up and tweaking the kit.
    Now if you want to build yourself a beast then theres nothing that ses power then some good old 1/2" tubing alround and a custom built kit from random parts puttogether to make a very good system.
    A basic watercooling kit consists of
    Res [unles you opt for a closed loop in which case not needed]
    Pump
    CPU block
    Tubing
    Rad + Fan
    If you do it yourself you tend to alwasy come up with better results then a kit unless you completly screw it up.
    What you wanna look for these days is :
    CPU block - Danger Den RBX_Good little current perforumer, good for everyone to use and will give good results.
    D-tek white water_More towards the extreme althoughs ome ppl say that the RBX performs better, tiss a good block and very stable been used alot over the years ppl rate it as a very good piece of kit.
    Little Rivers Cascade - This is the current dady of blocks, outperforms everything ont he market. Its the extreme end of the spectrum :D
    Pumps - Your looking at most eheim 1048 > 1250, or L20/30 there all good in the end will give good flow at good pressure.
    Radiater - You can get a rad from a single 80, to double 80s too 16x120s. but comenly ppl use either a single 120mm rad or a double or tripple these give the best results and tend to fit inside your case. Black Ice and thermochill are very good rads to go for. You could always get a care heatcore and use that do it the modders way :thumb:
    Reservior - There are many available ont he market the more user friendly id say are the bay reses. These take up either single or double 5.25/3.5" bays and give a very good solution for carring your water :D
    Additives - if your starting out and don't want to experiment with additives Water Wetter is simple to use and gives great results and will stop all sorts of interesting things happening to your water and your blocks, there are many threads available that discuss additives if you care to do a bit of searching around.
    additions to the loop can be added like GPU, HDD, NB blocks etc... and even PSUs although little pricy interesting idea.
    Links
    Coolercase - UK distributer of Danger Den products. Large range of watercooling and computer components, quick service and great staff e-mail Coolmiester if you have queries or email me if you wish :thumb:
    D-TEK - Retailers of the White Water block.
    Over-Clock - WIde range of watercooling porducts. Also sell heatcores as well as some good rads
    Wizard Designs - This is more of the 3/8" flavour, great selection of products and the msot friendly of staff. Look around on the boards for PUG.
    Hope thats helped
    Good luck
  11. Risky
    Risky Modder
    10 Sep 2001
    You could also look at Swifttech's range, which looks pretty good to me. www.swiftnets.com
  12. orb
    orb satisfying.
    23 Dec 2003
    How much would it cost for a nice water cooling system? ie. the cheapest?
  13. richman
    17 Sep 2003
    i have seen a watercoling kit @ dabs for £60 i was like OMG this must be the wost kit on the market, as my pholosophy to kit is "you get what you pay for" so a cheap kit would under perform or break after 5mins of insterlation :hehe: where as if u save a bit then splash out on a mean kit you would get some nice temps and also you would have a good bit of kit that is going to last you.
    Richman
  14. richman
    17 Sep 2003
    forgot to add i have been doing some research aswell and have come up with the following kit, if anyone is intrested :worried:
    Reservoiur - Typhoon Bay Res £25.99 www.coolercases.co.uk/wc_reservoiurs.htm
    Pump - Eheim 1048 Pump £36.99 http://www.coolercases.co.uk/wc_pumps.htm
    Radiator - ThermoChill 80.1 £49.99.?? http://www.coolercases.co.uk/wc_radiators.htm
    Radiator Fan - 80mm Sunon Fan £6.99 http://www.coolercases.co.uk/fans_standard.htm
    Additives - Water Wetter 50ml - £4.99 http://www.coolercases.co.uk/wc_additives.htm
    Blocks - RBX P4 478 £45.99 http://www.coolercases.co.uk/water_blocks.htm
    Hose - 12mmX3mm Wall £1.59p Per Meter http://www.coolercases.co.uk/wc_hose.htm
    Iam not 100% sure on hoses and clamps so i still need a bit of advice on them if someone would like to explain which i should use i was thinking of going 1/2"
    Cheers
    Richman
  15. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    that setup looks good to me, might want to consider the RBX over the Maze 4 as it has more potential :p.
  16. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    Get a Cascade or a SIlverprop SE, The SE is a shiny bugger.
    BTW: These are Aussie blocks so AUSSIE AUSSIE AUSSIE OI OI OI!!!
  17. realhorrorshow
    realhorrorshow What's a Dremel?
    6 Aug 2002
    OK I'm a water Noob too. What is the deal with the 3 barbs on the RBX how does it connect up? It's this that makes me think i might go for a maze4 - just simplicity for a first timer..
  18. richman
    17 Sep 2003
    Hiya,
    M D K considering your advice i have changed the block for the RBX P4 478 :rock: it is only £5 more and as you said it has more potential :D , also wat is the deal with the 3 connectors on that block what are they for? :eyebrow:
    Edit: Found Some Hose
    Cheers
    Richman
  19. richman
    17 Sep 2003
    Can anyone help?
    Cheers
    Richman
  20. Darv
    Darv Bling!!
    12 Aug 2002
    Well on a Maze 4 the water goes in one side and coems out the other. With an RBX the idea is that water is sprayed directly onto the area of the CPU die. This means the water will be coldest when it hits the hottest part of the block. The two barbs either side are to ensure that the water spread evenly across the rest of the block. From there the water can be then joined back together by using a Y adapter or can be seperated to other sections like NB and GPU.
