Modding Nooh's Watercooled HD3870 & Modded Rad Housing
Discussion in 'Modding' started by nooh, 3 Dec 2007.
  1. nooh
    nooh What's a Dremel?
    7 Sep 2006
    I bought something which is red coloured and I had to put it inside the fusion block . Is that the thing?
  2. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    News to me. I assume this done to pre-stress the base so that it becomes flat when installed?
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    No, to bulge out the base so that it makes better contact with Intel's concave IHSes.
  4. eegg
    eegg What's a Dremel?
    29 Aug 2006
    what do you make at that workshop?
  5. nooh
    7 Sep 2006
    SO where do you get this Oring from ?
    they make showcases www.hitechshowcases.com
  6. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    Great job, I hope it runs nice and cool. That's quite a setup you have there and I find it quite funny that it says "What's a dremol" under your avatar lol. I think it should say "What a dremel to my uber mega shop of modding goodness?" Keep up the good work my friend.
  7. ledbythereaper
    ledbythereaper What's a Dremel?
    2 Jan 2007
    Nice to see you take my advice nooh :)
  8. nooh
    7 Sep 2006
    Done the handles for it. :)
  9. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    Shouldn't each of the three rads get their own air intake so that they aren't heating each other up?
  10. nooh
    7 Sep 2006
    Dunno , I tried two together and it was great. Still have to try all 3 in windows.
  11. nooh
    7 Sep 2006
    Ok guys so here it is.
    So its finally finsihed. Its up and running and I feel releived. Enjoyed doing the whole project but there were times when I felt like putting it all in the bin.
  12. nooh
    7 Sep 2006
    After I finished doing all the piping and installing of the hardware I decided to finally bang some lights in .I realised I still need to play around a little and get the right lights in order to get the right finish. Also I purchased a meter of the coloured tubing too and never used it but in the end it came to good use.
  13. nooh
    7 Sep 2006
    As you can see I have too much lighting in there and some of it is the wrong kind. So I plan to order some small ones which are £2.99 or something more a less them lines.
  14. nooh
    7 Sep 2006
  15. nooh
    7 Sep 2006
  16. nooh
    7 Sep 2006
    did some of my posts get deleted ?
    I am sure I uploaded some images today.
  17. francisl1420
    francisl1420 What's a Dremel?
    23 Jul 2007
    What sort of temps are you getting?
  18. nooh
    7 Sep 2006
    Temps on the CPU is 47c core temp. I remember before it was bout 60c on coretemp. I havent overclocked it yet will do tomorrow or so.
    I was going to use all three rads just for the CPu first and later buy blocks as I can afford it but then I breaked in to my piggy banfk and killed it all.
  19. nooh
    7 Sep 2006
    storage spcae in the Xclio is great.Rearranged the pipe work a bit and it looks awesome. Well I think it does. :)
  20. francisl1420
    23 Jul 2007
    That 47 under load?
