Disaster Noooooooooooooooooooooo!!
Discussion in 'Modding' started by Tim S, 21 Mar 2004.
  1. Tim S
    Tim S OG
    8 Nov 2001
    http://www.whos-j00r-daddeh.net/bigz/images/deadasadohdoh.jpg
    I fired the card up earlier today to find that the vGPU mod wasn't working... loose connection, fair enough, resoldering job... I think.
    Anyway, after removing the old wiring, I soldered the first wire on, ok fine, good connection, etc... looked neat, no problem...
    Stupidly enough I then rushed a little on the second wire, and managed to get too much solder onto the wire, and then the bi product of this was that I managed to bridge together 2 of the legs of the IC with the excess solder, and it managed to find its way underneath the regulator, somehow... there wasn't even THAT much solder on there! :blah:
    Oh well, my first "disaster mod" for a long while, I don't mod much these days apart from volts, so it can get quite expensive... :p
    Luckily this was only a £100 card which has had a good bit of usage out of previous to this misfortune. The down side is that I've gotta find a new 9600XT which will overclock to the same heights... 762 core from 500 core, is well... a rather insane 52.4% overclock. :)
    Chances of this are very slim, but it was a fun card for a fun project, sadly it's been cut a little short by my impatience... really shouldn't have soldered after a bad day at work. Silly me, I'll learn :waah: :waah: :waah:
  2. Mister_Tad
    27 Dec 2002
    RIP
    :waah:
    g'luck with your next victim :)
  3. Tim S
    Tim S OG
    8 Nov 2001
    btw if you ask what is wrong with the card, you will see a little chip to the left of the VGA connector, that should be where the wire is attached :) It controls the voltage to the GPU
    the card should look like this
    http://www.uploadit.org/L337M33P/blah-046.jpg
  4. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    :duh:
    Sell the fx53(I am somewhat serious, your other rig is great... and you know damn well you could build a whole computer for 800 dollars :p)! lol... man that sucks. Good luck finding a new card as good as that :wallbash:
  5. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    get a radeon 9800XT or Pro if you have a FX-53, come on.
  6. TMM
    TMM Modder
    12 Jan 2004
    couldn't you buy a cheaper card (9200 or 9000), they should use the same chip there :\
  7. Tim S
    Tim S OG
    8 Nov 2001
    The FX-53 was on loan, it's not my processor. :)
    I also have a 9800SE @ PRO as my day to day card, this is my hobby card that I've killed.
  8. Darv
    Darv Bling!!
    12 Aug 2002
    That really sucks. :( It was an amazing clocker while it lasted.
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    lol, bad luck bigz, good going "slick" :p
  10. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Shotgun!
    I reckon there's a slim chance of revival tbh
  11. Tim S
    Tim S OG
    8 Nov 2001
    I'm gonna try and get hold of the part number and resolder it on... however I think it's fubar as a couple of the traces might be damaged. :)
  12. TMM
    TMM Modder
    12 Jan 2004
    yer, go for your life, its worth the effort id say :p
    If you can't get it going, ship it to me ;) heh
  13. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Wish you the best of luck (and errr patience ;)) With it next time.
    and I must say WOW... I never new that a vid card could be OC'd that far :jawdrop: I can only pull an average of about 10-20%. but thats with no volt modding and stuff like that ;)
  14. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    If you need a hand repairing the card once you get the IC bigZ I'd be glad to help. Im and electronic engineer by day and I can cope with a lot of the smaller SM rework. As long as I dont have to save the IC im taking off im fine :D
    I also have magnifiers etc here to see if there are any lost traces.
  15. hypocrisy86
    hypocrisy86 Banned
    27 Jan 2004
    That sucks..
  16. Auron
    Auron What's a Dremel?
    23 Jan 2004
    Ack, at least it didnt set on fire like one of my spare PC's t'other day :hehe:
    Whats teh next project? :p
  17. Tim S
    Tim S OG
    8 Nov 2001
    Thanks for the kind offer mate, I will definately consider this offer if and when I get hold of the IC :)
