Electronics Noritake 128x64 VFD technical thread
Discussion in 'Modding' started by linear, 13 Jan 2003.
  1. Somm
    Somm What's a Dremel?
    14 Feb 2003
    I just got my display yesterday, wired it up according to the liquid mp3 wiring. It works fine with the animation player and the blinkenlights player but can't get liquid mp3 to run. All it seems to do is clear the bottom line over and over when i try to start the plugin. :( any ideas??
  2. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    got the right portio for you OS... Make sure you have the NT version if you are in XP, 2K or other NT... Otherwise you have some of the wires with iffy connections...
  3. Zotty
    Zotty What's a Dremel?
    9 Sep 2002
    OMG, I wish I've seen this thread earlier! Anyways, maybe it's not to late yet, so if there are still some unanswered questions... :lol:
    Btw, thank you for all the compliments about LiQuiD-MP3. This only encourages me to me it better :naughty: Now if I only get that damned modelengine to work properly....
  4. ChriX
    ChriX ^
    30 Aug 2001
    /waves to Eelco ;)
  5. ATFNegotiator
    ATFNegotiator What's a Dremel?
    14 Jan 2003
    hmm im guessing zotty is liquid mp3 creator :D welcome
  6. linear
    linear Minimodder
    5 Oct 2001
    Hi, Zotty, I'd say welcome but you registered months ago! So good to see you again then.
    I'd say we've now heard from all the heavy hitters in graphic LCD/VFD software development in this thread. :rock:
  7. Zotty
    9 Sep 2002
    /me waves to ChriX and thinks "man, is there any forum in this universe where this guy can't be found?" :p
    Yepz, I'm the creator of LiQuiD-MP3 and it's true I registered months ago (hi all ;)) But I don't post on forums as much as I used to anymore. I've got so many other things to do that posting has become a low priority thingy on my to-do list. But let's get back to the VFD stuff. I'll bet there's more to talk about!
  8. Pflumingo
    17 Jul 2002
    Hey Zotty, When's the scroll gonna work on the Noritake for the title/track... All I get with it enabled is rolling hyrogliphics...
    Just wondering. Otherwise, Nice Plugin.
  9. Zotty
    9 Sep 2002
    Scrolling indeed doesn't work on Noritake and KS0108B modules. Not yet anyways, because the scrolling routine is going to be rewritten. The current scroll code was written when I was still learning to code and it's pretty crappy :worried: Secondly, it's speed is dependant on the updatetime, and that is far from perfect. So when it's being rewriten, Noritake (and KS0108B) scolling will be working. Besides, scrolling per pixel looks great on VFD modules, so it has to work :D
  10. PrimusSucks
    PrimusSucks What's a Dremel?
    28 Nov 2002
    Ain't my wiring as far as I can tell. Didn't someone else complain of this? What happened?
  11. dakar
    dakar What's a Dremel?
    6 Mar 2002
    I'm in the same boat... I have to be overlooking something somewhere... re-wired three times now using new parts.. I used 26 pin printer port header connectors from old mb's (they are keyed so you can't hose it up). But i'm still not any further than that orange glow.
    It's got to be something really obvious... isn't it always?
  12. Morphine
    Morphine weeee!
    23 Feb 2002
    ice got two of them doing exactly the same things as you guys, nothing at all
  13. nixk
    nixk What's a Dremel?
    17 Feb 2003
    I had the same problem with just getting orange wires. I changed my parallel port settings in my bios from ECP to just a normal parallel port and everything started working.
  14. PrimusSucks
    28 Nov 2002
    Changing to SPP didn't help. Fuse is intact.
    Do thay all do the glowing orange thing upon initial power up?
  15. PrimusSucks
    28 Nov 2002
    Did ice only get two. Or more than two? This would clarify if it is a dead display or not because a cable that worked on one, would work on the two that act as mine.
  16. Pflumingo
    17 Jul 2002
    Yes, All glow orange.
    and I thought I borked mine a couple times, I had to look twice, as I had the d0 thru d7 backwards at first... Got NOTHING out of it till I changed it.
  17. Zotty
    9 Sep 2002
    If there are several persons wanting a little test app (using this wiring), I'm willing to make something. The demo's Henri made :)clap: ) work with WinIO if I'm not mistaken, so a little DLPortIO testing might still be usefull. Let me know if there's any interrest in this.
  18. zeewin
    zeewin What's a Dremel?
    9 Feb 2003
    A test app sounds good, as I am still awaiting my displays and would really like to get a handle on the setup before touching the display.
  19. nixk
    17 Feb 2003
  20. ATFNegotiator
    14 Jan 2003
    how's it work, i get: Component 'COMDLG32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
    can u help? :|
