Electronics Noritake 128x64 VFD technical thread
Discussion in 'Modding' started by linear, 13 Jan 2003.
  1. PrimusSucks
    PrimusSucks What's a Dremel?
    28 Nov 2002
    I'll give the test app a go as I am getting somewhat frustrated.
    Speaking of this diagram ... for those of us that are not electronic gurus, that bridge in the diagram may be a bit confusing for some. I realized that D1 goes to DB1 from my 4*20 VFD experience. Though, I have read in other forums where peeps wired straight across. i.e. DB7 to D0
    The diagram is not at fault... just not noob friendly. :D
  2. SleeperDC
    SleeperDC What's a Dremel?
    29 Oct 2002
    i am also using a old printer port header from mb....the other end fits perfectly on the VFD...
    and all i got are also those orange lines...
    i got a friend of mine do the soldering...he's a pro, and i've checked million times, so shouldn't be a wiring problem...
    i am going to change my printer cable and see...
  3. nixk
    nixk What's a Dremel?
    17 Feb 2003
  4. dakar
    dakar What's a Dremel?
    6 Mar 2002
    This may really seem dumb (and probably is)... But after re-reading Linear's post of the wiring diagram again and again... I must not have looked too hard to the bottom of the post where he shows the pin outs of the parallel cable he built (i found in one of my parts bins a straight thru M-F DB35 cable so i used that) But are the pin-outs reversed by row from end to end?
    ie... 1 -> 13 and 2 -> 12 etc... or is my imagination running amok from too much reading?
    Could explain why things are hosed. As i've got everything wired straight thru to the para. port from the VFD, then all of the pin-outs are reversed.
    I'm at work now, although i admit i'd enjoy manufacturing an excuse to run home to try something.
    But i have a feeling i need to start warming up my boots for a firm kick in the tail end......
  5. ChriX
    ChriX ^
    30 Aug 2001
    Nice of you to modify my work and post it on the internet without even letting me know.
  6. nixk
    17 Feb 2003
    I dont want to get into an argument here, but I did not modify your work. I just wrote a program that had the same functionality. I wrote it orignally as a test app just to learn programming the VFD. Someone asked about a test app that used DLPortIO so I posted it to be helpful.
  7. ChriX
    ChriX ^
    30 Aug 2001
    Sure you did. You have clearly taken my skin and made loads more 'based' on it.
  8. nixk
    17 Feb 2003
    Okay, I agree with you there. I thought you were referring to the BlinkenLights application since you made no reference to the Liquid MP3 skins in the previous post. As you see from the website, I clearly state that the skins were based on your skin. I did not realize you needed to know about it before I posted them. I am sorry. If you would like, I can take them down. I just figured that some people would think they look neat and maybe want to use them.
  9. ChriX
    ChriX ^
    30 Aug 2001
    No, you can leave them up, it's fine. I just would've liked to have known. :)
  10. nixk
    17 Feb 2003
    Thanks,
    When I posted them I didn't even realize that you were the one who created the original for Liquid MP3. I thought the one that you posted on here was one you modified from Liquid MP3 to make it fit the screen better. Like I said before, I am sorry. I am not trying to start trouble, I am just trying to help contribute to the community around this VFD. :D
  11. ChriX
    ChriX ^
    30 Aug 2001
    No worries. :)
  12. SillyGoose
    SillyGoose What's a Dremel?
    10 Feb 2003
    newbie here, can someone take an actual picture of their wired vfd? I think I can follow the instructions but an visual would be real nice.
    and the seller from ebay shorted me a display. and he doesn't have anymore in stock. sucks!
  13. Dyne
    Dyne What's a Dremel?
    7 Mar 2002
    Ive finally gotten around to wiring my displays, but have a question
    I know that the parallel port does not supply enough power for the vfd, nor does the usb port. Is it possible to somehow wire it up so that you could use multiple ports to power it?
    a molex connector sticking out would kind of look pretty crappy
  14. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    No, Combining them creates another problem althogther... Just run a tracer with the 5V down your parallel cable from your psu, close to the port (Could even snake it out where one of the screws goes...)
  15. Dyne
    7 Mar 2002
    ok I've finished wiring it (using the liquid-mp3 wiring), and just installed the winamp plugin
    The screen that shows up on the vfd is somewhat garbled, and the layout changes everytime I stop and restart the plugin.
    by garbled I mean well, just messed up, like columns or rows that dont display anything, the window out of place, somethings squished or elongated.
    Im 90% sure that I wired everything up right, so Im thinkin theres some sort of software conflict
    can anyone help me?
    edit: I went into BIOS and changed the parallel port settings to ECP + EPP and it seems to work fine now, I guess it didnt like SPP
  16. Zotty
    Zotty What's a Dremel?
    9 Sep 2002
    It seems DLPortIO 'talks' to the parallelport in a different than WinIO does. On my forum, justin posted he could run the demo's from Henri (using WinIO) fine, but LiQuiD-MP3 (using DLPortIO) didn't work. After changing the port settings in the BIOS it worked fine.
    This info might help some people solve their display problems :)
    edit:
    I just saw that Dyne confirms this in his post above.
  17. ChriX
    ChriX ^
    30 Aug 2001
    Do you mean like a pic of the back?
    http://www.icehw.net/article/graphic_vfd/connect.jpg
  18. jfields
    jfields What's a Dremel?
    18 Feb 2003
  19. nixk
    17 Feb 2003
    Re: Source Code
    I used the Liquid MP3 wiring but it would not be hard to modify it to use the other wiring.
    I will try to post the source code this evening but I am warning you its pretty ugly. (atleast the blinkenlights specific stuff, the actual communication with the VFD is pretty straightforward).
  20. Dyne
    7 Mar 2002
    :D
