Electronics Noritake 128x64 VFD technical thread
Discussion in 'Modding' started by linear, 13 Jan 2003.
  1. Morphine
    Morphine weeee!
    23 Feb 2002
    Ill try setting the parallel port settings in the BIOS when I get home, maybe thats whats keeping my PC from "talkin" to the VFD. I would love to get the Liquid-MP3 plugin working. It would look sweet on the front mof m case.
  2. SillyGoose
    SillyGoose What's a Dremel?
    10 Feb 2003
    yea, I did, is that a floppy cable? I thought you guys soldered the wires straight to the pcb. so you solder the other end of the floppy cable to a cut printer cable?
    thanks in advance!
  3. Dyne
    Dyne What's a Dremel?
    7 Mar 2002
    I cut a floppy cable to fit into the parallel port on the vfd, and soldered the wires from the parallel port cable to the wires on the floppy cable (did that sound confusing?)
    anyway, when I try to do "scroll artist" or "scroll title" in the liquid-mp3 plugin, the text on the vfd gets all garbled. Ive tried all the different settings in BIOS, but the same thing happens
    Also, has anyone made different skins for their display? When I try to modify the liquid-mp3 one, like half the colors get reversed, so it doesnt look good.
  4. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    Yeah, I have made skins, and changed layouts, And zotty said the Scroll features don't work on the 800's yet, Look up a bit...
    Gotta conform to where the display is set, or change the settings for where to display..
  5. SillyGoose
    10 Feb 2003
    hey tks Dyne!
  6. ChriX
    ChriX ^
    30 Aug 2001
    http://www.icehw.net/article.asp?id=143&page=3
  7. ChriX
    ChriX ^
    30 Aug 2001
    The scrolling is not enabled for the Noritake 800 Series and KS0108 modules in this version.
    As for skins, I made the one that comes with LiquidMP3. Make sure you save as a 144x64 2-bit bitmap.
  8. nixk
    nixk What's a Dremel?
    17 Feb 2003
  9. Zotty
    Zotty What's a Dremel?
    9 Sep 2002
    Cool skins! Mind if I add them to the skin gallery on the LiQuiD-MP3 site? :naughty:
  10. ChriX
    ChriX ^
    30 Aug 2001
    Hehe, you'll have to be on multiple pages soon mate! :rock:
  11. nixk
    17 Feb 2003
    That would be fine with me. :)
  12. IZen
    IZen What's a Dremel?
    20 Feb 2003
    Win98 Liquid MP3 tip passed on
    Hi all, My first post all though most of you received my email. I'm the guy, Scott W., that sent the email to everyone that purchesed these on ebay.
    Thanks for all the responses. I've forwarded everyone that didn't already know about these threads, here and to HardForum.
    After several hours of trying to prove to myself that my displays actually function, I found the tip that got me up and running. Here is the quote from the Yahoo group: "Noritake VFD"
    From: "scs_robert <hottdoggzz@h...>" <hottdoggzz@h...>
    Date: Wed Feb 19, 2003 7:05 pm
    Subject: Win 98 tip .. rename Liquid MP3 dll
    I was not able to get Liquid MP3 to work with Win 98 (Winamp 2.x)
    until I renamed the .ddl file to vis_liquid. Winamp could find the
    plugin with the name supplied by the installation.
    I didn't have to do this on my XP installation.
    This simple rename from vis_liquid-mp3.dll to vis_liquid.dll and a restart of the plug-in under winamp and bingo all's well in the world. 3 hours of ohming connectors for nothing but alls well that ends well. I'd recomend this to anyone that is having trouble with liquid mp3 under Win98.
  13. zeewin
    zeewin What's a Dremel?
    9 Feb 2003
    OK , I must look like an idiot but for some reason the Liquidmp3 plugin will not showup under my Winamp>Preferences>Plugins>Visualization
    Winamp 2.60
    LiquidMP3 .93
    DLPortIO
    I checked the Winamp>plugin directory and the dll is there (renamed to vis_liquid.dll). I have restart Winamp about 4 times already. The Q&A's on the LiquidMP3 site states the following:
    Q: I copied the plug-in to Winamp's plug-in dir, but LiQuiD-MP3 is not shown in the plug-in list.
    A: Did you install DLPortIO? When DLPortIO is not installed and running, Winamp is unable to start the plug-in.
    I have installed DLPortIO already and restarted the system but Liquid still fails to display in the Visualization>Plugins directory.
    Is there something else I am suppose to do that I may have overlooked?
  14. zeewin
    9 Feb 2003
    Got it, I had to flush the Plugin cache.
  15. Zotty
    9 Sep 2002
    Hmmmz, it seems I'll have to work on the LiQuiD-MP3 FAQ. Expect an update before the end of next week!
    Does the "-" character cause the problem under Win98? If so, I'll take that in account in future plugin naming.
  16. zeewin
    9 Feb 2003
    Well I recieved my displays on Tuesday and successfully built the cabling and now they are up and running with the LiquidMp3 plugin.
    I have to hand it to all of you for your teamwork and dedication to get these displays working, without you guys I would have been dead in the water!
    Is there a test screen utility(virtual screen) I can use to test the plugin configuration so I don't have to have the VFD connected at all times?
    *I am not at home so I cannot test the dll name change. I will update on the name change in a few hours though.
  17. Zotty
    9 Sep 2002
    I'm working on the FAQ right now, and was wondering if there are things you guys (or girls :lol:) find usefull in a display/plugin FAQ. Since I'm working with displays daily, I'm affraid some things will be forgotten that might be usefull to the occasional display-user. So if you have good ideas and/or tips, let me know!
  18. zeewin
    9 Feb 2003
    I have the displays working on a desktop with no problem but testing on my Armada(compaq laptop) the display is garbled and off center. I checked the bios settings for thelpt1 and the only options are:
    Standard
    Bidirectional
    EPP
    ECP
    There is no setting for ECP+EPP The best setting I tested was Bidirectional but still the display is garbled.
    Is there any specific port setting I must change in the OS? Or in DLPortIO?
    I am testing on this laptop to see if the dll name change has a problem.
    Thanx
  19. Zotty
    9 Sep 2002
    LOL, you're throwing everything you've got at it aren't you? Now I'm starting to get worried you're going to find all weak points in the plugin hehe :worried: :p
    Laptops are an unsolved case. I have never seen or heard that it worked on a laptop, but I did hear and saw it didn't work.... It's a timing problem, and every laptop (from expensive ones to the cheapest junk imaginable) seems to suffer from this, no matter what port setting is used.
    More info on this is much appreciated!
  20. Pflumingo
    17 Jul 2002
    Hey Chrix, Went to Ice hardware, and checked out your article on how to hook up the LCD... Just a note that the number of reads updated +1 every time I changed pages on it... So I read the article one time, but it added 5 reads... I think you might want to check that... Good article tho.
