Modding Noritake GU126x32F-K612A4 graphic VFD
Discussion in 'Article Discussion' started by Cheese, 19 Jul 2002.
  1. poody
    poody What's a Dremel?
    20 Jul 2002
    Acually (I think) only the last number is the firmware version. It's acually K6XXYZ. XX is the interface type (10 Async/SPI, 11 RS485/SPI, 12 RS232/SPI), Y is the power (A is 5v/500mA, C is 12v/250mA), and Z should be the firmware version. So if you want one that works with RS485 and runs on 12 volts, get the K611C3 instead :).
    Hope this helps.
  2. Cheese
    Cheese Doc
    6 Oct 2001
    Thanks for the info guys :) ...and welcome to all the new sign-on's :D
    Some links to filter companies,
    Optical Filters Ltd
    14 Bertie Road
    Thame
    Oxon
    OX9 3XA
    tel: 01844 260377
    fax: 01844 260355
    web: www.opticalfilters.co.uk
    Contacts: Peter Fisher, Samira Adlane
    Clarex /
    Weatherall Equipment & Inst. Ltd
    Unit 1, Station Approach
    Wendover
    Bucks
    HP22 6BN
    Tel 01296 622180
    Fax 01296 624955
    Contact Roger Worthington
    email: rhcworthington@msn.com
    Web: www.weatherall-uk.com
    Instrument Plastics Ltd
    35 Kings Grove Ind Estate
    Maidenhead
    Berks
    SL6 4DP
    Tel 01628 635961
    Fax 01268 773299
    Contact Mike Wevill
    Lee Filters
    Central Way
    Walworth Ind Estate
    Andover
    Hants
    SP10 5AN
    tel: 01264 366245
    fax: 01264 355058
    Web: www.leefilters.com
    Contact: John Young
    Though I've never dealt with any of them :(
    Also farnell sell some filters in small quantities, no blue though :(
    Cheers,
    r.
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I presume u can do 20fps with these serial ones ??
    Could u make some really l33t animations when switching to stuff like winamp etc?
    /me thinks about the pioneer car stereos with the dolphin animations
  4. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    Nice one Spike, i was thinking the same! So we're looking at 50squid plus VAT for these babies, and we can create animation for them how? The outputs you had from LCDC are great Cheese, love to know a lil more about animation, can LCDC cope, i haven't really used my LCD since my mobo died and the poor student i am can't afford a new one, but may be able to afford one of these! lol for now on a decrepid 266... :(
  5. Guest-2808
    Guest-2808 Guest
    Unfortunatly, not with the serial displays...
    19600 baud, 126x32 = 4032 pixels. 19600 / 4032 gives 4.8
    complete frames per second. It's actually lower than that,
    because there is the command transmission and processing
    overhead too. I'd say 4fps was about maximum, and you need
    at least 12 for animation. You could probably do an FFT
    scope for WinAMP at around 15 fps if it wasn't too big.
    That's basically why I got the parallel display, you can do
    about 1000 fps! I have some nice animations going :)
    As CheeseMan said, it is harder to connect a parallel
    interface, but worth it I think. Shame about the software,
    although I did find this WinAMP plug-in:
    http://www.markuszehnder.ch/projects/lcdplugin/
  6. Cheese
    Cheese Doc
    6 Oct 2001
    Yep as the man says, a full screen bitmap animation at 20fps is a no no, though a full screen of text at 20fps isn't a problem o/c. Also a winamp bar equaliser or scope should be doable, or a screen with a couple of small animated icons (spinning discs etc.).
    LCDC might be able to handle a little bit of icon animation, I'm playing with that atm, but a winamp equaliser in LCDC seems out of the question at the moment.
    Cheers,
    r.
  7. Puk
    23 Mar 2002
    Hey AmiMoJo, what programs do you use or do you write them yourself? I'd really love to do the animation and so i guess shall have to look into the // displays but i'm really not clued up enough to write my own software. If your able to map every single pixel then linux would be so easy to use for some serious 3D anime, have to look into this a bit closer.
  8. Guest-2808
    Guest-2808 Guest
    I write my own software, in C and/or assembler as appropriate.
    You could do some Linux software fairly easily if you knew
    how to code, the parallel interface is quite easy to use.
    I'll put up a web site with software, code and hardware
    details at some point.
  9. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Nice , nice
    nice , Very Nice !
    too bad there is only a 5V output ...
    but thats just 1 little minor ...
    I'm very impressed ... I was on the edge of buying a Matrix orbital (the one that has been reviewed by bit-tech) , but now I'm doubting !!! (damn you) lol
    its very positive that it only needs 1 bay slot .. cuz I only have 1 available
    well uhm ... thats about all I have to say about this ...
    :D
  10. poody
    20 Jul 2002
    Has anyone had any luck with purchasing one of these? I tried contacting noritake USA using the form but I haven't gotten a reply yet.
  11. Funks
    Funks VFD man
    22 Jul 2002
    Noritake GU126X32F-K612A4
    Hi,
    Just a quickie from me here at Itron (UK) Ltd to say THANKS to :: Cheese :: for the nice review, and to all of you that want to try this VFD display, to say that they are available, the spec is now on our web site. Any enquiries that you've sent to the Noritake sales offices will be answered shortly. Japan is on a summer shutdown this week, so one or 2 of you may experience a small delay.
    However, if anyone wants to contact Noritake Itron direct, please contact me directly, p.dakin@noritake-itron.com and I will help all I can.
    Thank you all for being so enthusiastic about our VFDs.
    Best Regards,
    Phil Dakin
    Itron (UK) Ltd
    EDIT: Changed contact email address.
  12. riggs
    riggs ^_^
    22 Jul 2002
    nice...
    Waahaay!
    Great displays - I really want one but can't afford anything at the moment!
    Have been thinking 'bout getting a display for a while (was gonna go with MO, either a graphic LCD or a nice funky VFD) - but after reading this review, I'll go with Itron methinks! Saves me having to make the choice of either nice graphics with an LCD, or nice look with a VFD...instead, I get a nice looking, graphic VFD...:D
    As there are UK sales depts. too it'll be easier to buy than MO (that's one thing I wasn't looking forward to with MO - I live in the UK so shipping would be evil - plus, no doubt I'd have to pay duty fee's ontop!!!).
    Anywho, cool display + very good review (told me everything I need to know).
    Matt
    (oh, and Goo, if you're out there, I really like your case! So much that I'm gonna nick the design but just use sticky back film instead - I'm not confident enough to put bolts through my drives ;) ):D
  13. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    Nice write-up, I sent an email last friday asking about prices and availability in the US, here is the response i got today for anybody interested:
    Thank you for your inquiry regarding our GU126X32F-K612A4.
    You can place the order to us directory.
    Unit price for one piece is $138.25.
    Unfortunately, Noritake USA does not have any stocks for this
    item now. I will ask the availability for this item, and our
    standard lead time is 14 to 16 weeks.
    If you have any questions, please contact me.
    p.s.: I will go to business trip on the week of 7/22/'02. So if
    you would like to contact to Noritake, you can con tact our
    George.
    Tel: (847) 439-9020
    email: george.ele@noritake.com
    Doesnt sound too promising, If anybody has a better (quicker) line on one of these for US peeps, plz lemme know.
  14. Funks
    Funks VFD man
    22 Jul 2002
    Availability Noritake VFD
    Hi UnLoadeD,
    You want to know ... If anybody has a better (quicker) line on one of these for US peeps, plz lemme know.
    And our US sales office said ".... I will ask the availability for this item, and our standard lead time is 14 to 16 weeks."
    Nearly every US sales office has enquired, and we gave them the GOOD NEWS, that we here at IUK will try to fulfill our overseas orders in 10 to 12 working days FRO and dispatch to our North American sales offices. So allowing for shipment times too, means that I estimate 3 to 4 weeks should be this products worst case delivery. (However, I hope that the they will order several so that have a few for stock too!)
    So please don't think that you'll have to wait forever and a day (well, 14 to 16 weeks!) we hope to do a bit better than that.
    EDIT: PLEASE send your order to ITRON (UK) LTD at sales@noritake-itron.com We will then deliver from the UK.
    EDIT: See later postings for more details.
    Please stick with us, you'll have a fantastic little display eventually!
    Phil,
    Itron (UK) Ltd
  15. riggs
    riggs ^_^
    22 Jul 2002
    Prices...
    So, Funks/Phill...
    What's the price of these units? Was the £50 guesstimate about right, and what are your delivery charges like???
    Cheers
    Matt
  16. Cheese
    Cheese Doc
    6 Oct 2001
    UK pricing £66.68 for display, cables, connectors AND a small blue filter. This is inclusive of delivery and VAT. Order kit KGU126X32F-K610A4 :eeek: Thanks Phil!
    Cheers,
    r.
  17. fathazza
    fathazza Freed on Probation
    20 May 2002
    whats the cost for the power and serial leads?
    seems like a damn good price for a vfd to me :)
  18. Cheese
    Cheese Doc
    6 Oct 2001
    Yep the price is great :D
    Info on the cables (product codes and prices) will be posted here when I get them (if Phil doesn't post them first) ;)
    Also,
    Datasheet available :: here :: now :)
    r.
  19. Funks
    Funks VFD man
    22 Jul 2002
    The Cheeseman is doing a great job here for you all, I want to publicly thank him for bringing our new VFDs to your attention.
    As he says we do have an Interface cable.... ready for this?
    IFCK0659FD-800A .... Phew!
    That is a 6 way Molex to 9 way D, with 800mm cable length and a RED and BLACK wire for the 5V and Gnd (0v). They aren't a plug connection, so you will have to crimp a suitable connector or solder to a circuit board for the 5V connections. (Sorry CheeseMan the D shell is black not blue!!)
    You can download a data sheet for this cable at http://www.noritake-itron.com/SubPages/vfcables.htm
    Now the bit you all want to know; How Much.
    For this I suggest you contact me at p.dakin@noritake-itron.com and I'll give you prices including delivery to your address.
    I'm pleased The CheeseMan has also made the full data sheet available, it was due on our web pages tonight, but this link is better for you I think.
    Any questions on the display and hardware, feel free to mail me direct if you wish, or post here for all to see (Good for FAQs)
    Questions on the way CheeseMan made the display work so well are best addressed to him.
    Phil
    Itron (UK) Ltd
  20. fathazza
    20 May 2002
    hi phil thanks for all the info,
    i was looking for maybe a bigger display , i was wondering what the biggest one ud recommend for under a hundred quid would be
    u guys might wanna think about putting a pricelist on ur website, it might make things easier :)
    + i dont spose anyine knows the maplin code for the type of plug needed for the power connector
    chers for the help
    hazza
Tags: Add Tags
