Modding Noritake GU126x32F-K612A4 graphic VFD
Discussion in 'Article Discussion' started by Cheese, 19 Jul 2002.
  1. Cheese
    Cheese Doc
    6 Oct 2001
    Re: Got my VFD!
    Hey hey, where'd you get off dissing my lil RS232-TTL convertor, I'm proud of that little baby :D It was designed to plug straight on to the back of the 40x2 Noritake VFD I made it for, so even if you looked at the back of the VFD you'd only ever see its bottom (and the reason it's really ugly is because of my scribbling on it, it was my first one so I had to make sure I got it right). Hehe I'll try and use some white PCB for you next time ;)
    Rob.
  2. riggs
    riggs ^_^
    22 Jul 2002
    Re: Got my VFD!
    Looks like some sort of glue to me...maybe hot glue, or possibly even epoxy.
    Matt
  3. The Colonies
    The Colonies What's a Dremel?
    5 Oct 2002
    Question for the Cheesie one...
    Rob,
    I have imported several of the screens from the first page and had a couple of issues with the actual display of them:
    1. Both Dragon and AMDnfo properly display, but then immediately clear line one thereby chopping off and blanking the top line. What am I doing wrong?
    2. AMDnfo was apparently using the font size from the previous screen and the HUGE fonts spilled over the edge. I solved this by placing this screen after the CPUinfo screen. Would there be a way to solve the font issue by specifying it in the code? I was unable to figure this out using the guides and such :(
    Thanks in advance...
  4. Cheese
    Cheese Doc
    6 Oct 2001
    1. You've associated the imported event with a blank screen which isn't really blank. If you leave the lines in a screen blank then LCDC will make the VFD print 21 spaces per line and hence draw over the image you've just put on the screen with the event. To stop this put 21 [##200]'s on each line, now LCDC prints 21 [##200]'s per line (instead of 21 [##32]'s - the space character), and character 200 doesn't exsist, so this really leaves the screen unchanged.
    It's either this or you haven't selected 'flip' for the screen's transition (the only transition that works with this display).
    2. Yep, in the event for the AMDnfo screen just add 'Normalfont,' to the start of the parameter line. This will make the display choose the normal font at the start of that screen :)
    Cheers,
    Rob.
  5. The Colonies
    5 Oct 2002
    programming stuffs...
    Thanks Rob!
    I am slowly starting to get it...well, at least I am starting to get how to modify existing work. I am quite a way from the developing my own stuff, I fear.
    Did I miss a tutorial on how to create opening macros?
    Not that I don't love the bit-tech logo and such, but I have been trying to reverse-engineer the Set macro 0-1 Event without success.
    If I wanted to, say, have Rob's Dragon and add a transition and a flashing SOYO logo or something, how would I go about this?
    Sorry to be so dense...
    ~B
  6. Cheese
    Cheese Doc
    6 Oct 2001
    Err if you look backwards in this thread there's a version of my excel icon maker that also produces a line which will set macro0 with the same pic... should help.
    Animations on power on didn't work for me, codes in macros are processed too quickly.
    Rob.
  7. aCe2k
    aCe2k What's a Dremel?
    1 Jan 2002
    Re: Got my VFD!
    First of.. thanks :D
    Well, i just dremiled som small "dents" so the standoff would match the the height that the VFC needed and to give the glue from the glue gun som hold... That's all :rock:
    Working like a charm it is :D
  8. prsmith777
    prsmith777 What's a Dremel?
    21 Jul 2002
    Case Pics
    I finally got the case I have been waiting for and put the display in. I like it on the top of my desk, so I can always admire it. Don't have to move the keyboard and look under the desk now.
    Hope you like it.
    Paul
  9. Kronenbourg1664
    Kronenbourg1664 What's a Dremel?
    29 Sep 2002
    working pictures would be nice
  10. Cheese
    Cheese Doc
    6 Oct 2001
    I fixed the piccies, the problem was just the host (geocities).
    Nice work, looks sweet :)
    Rob.
  11. Kronenbourg1664
    29 Sep 2002
    That does look nice
  12. sojumk
    sojumk What's a Dremel?
    11 Sep 2002
    Did they stop selling the package for $77? i want to get one too. :rock:
  13. Cheese
    Cheese Doc
    6 Oct 2001
    No, see 'The Colonies' post on page 44, you need to order through the US branch of Noritake to get that price (www.noritake.com follow links...).
    Cheers,
    Rob.
  14. sojumk
    11 Sep 2002
    read his post...am i suppose to call the brench in CA? or can i purchase it online? i went to the site but don't know where to go..:waah:
  15. Cheese
    Cheese Doc
    6 Oct 2001
    Send an email to their sales addie, you can phone if you want...most people here have ordered by email.
    Rob.
  16. WychDocta
    WychDocta What's a Dremel?
    3 Feb 2002
    Hey
    I got my new VFD, mounted n everythings going etc.
    I have MBM5 installed, using LCDC and MBM5 is displaying my CPU temp correctly in windows, but still displays 255C as CPU and Case temp.
    LCDC for some reason wont let me open the configure option of the MBM5 plugin
    anyone else have the same kinda problem, or has solved this?
    (edited, keep calling the damn thing an LCD instead of a VFD)
  17. Kronenbourg1664
    29 Sep 2002
    Set them up as sensors 3 and 4
  18. Kronenbourg1664
    29 Sep 2002
  19. Cheese
    Cheese Doc
    6 Oct 2001
    Pretty sure I used 2 and 3 when I wrote my temp screens... I could be wrong though, it was a long time ago :)
    Rob.
  20. Kronenbourg1664
    29 Sep 2002
    I had the same problem, and I have sorted it like so
    Originally i had
    sensor 1 - VIA686B-3 (CPU Temp)
    sensor 2 - VIA686B-2 (Ambient)
    Now
    sensor 3 - VIA686B-2
    sensor 4 - VIA686B-3
    Now it works
Tags: Add Tags
