Cooling Northbridge cooler + others
Discussion in 'Hardware' started by profqwerty, 26 Jan 2007.
  1. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    In lieu of my case mod, i'm trying to find a w/c for my northbridge. It's a P5WD2-E mobo; specs in sig.
    I'm going to try to watercool asmuch as is humanely possible - is it worth cooling RAM/MOSFETs/HDDs/etc?
    I am probably going to put a fet cooler on the X1900; IIRC there were adapter plates that connected the FET coolers to the main GPU block, but now cant' find any - they're all fully contained (expensive) blocks now.
    I might try doing the PSU if i feel brave enough...
    Can anyone recommend a decent cooler? I have alphacool CPU/CPU blocks atm.
    Also, I was looking into creating a waterfall effect - adding another layer of acrylic on the side/front and making the water flow through it; anyone with experience of this? I imagine sealing it will be a pain.
    Also do the bolts holding the mobo to the acrylic need to be grounded together?
  2. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
  3. Ener
    Ener What's a Dremel?
    17 Oct 2005
  4. profqwerty
    2 Jan 2006
    cheers, an interesting idea - certainly will try it out!
