Windows Norton 2005 Help/Question
Discussion in 'Software' started by Gabe, 4 Feb 2005.
  1. Gabe
    Gabe What's a Dremel?
    19 Jan 2005
    I have XP SP 2 and Norton 2005, the problem I have been having lately is when I am playing a multiplayer pc game, i get knocked out every 5 minutes getting a popup from "SECURITY ALERT" from norton asking if i want to permit/block a session and it gets really annoying and disrupts my game play. How do i turn the popup off? I even disable norton 2005 and it still comes up!
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    what's the game?
    is it legit?
    can't you just add it to the exclusions when the message pops up?
    click 'don't ask me again' (or whatever it is), then click 'permit'
  3. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    You sure its from Norton?
    Because I've had popus from the SP2 security centre before with games that try to connect to the internet.
  4. greshoff
    greshoff Minimodder
    29 Dec 2004
    Also had pop ups from Security sentre in SP2, not many from Nortons
  5. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    Err, what difference would that make may i ask? An illegal copy wouldnt cause a Security warning would it?
    Death
  6. atanum141
    22 Jul 2004
    I kno.....i kno!!!!!!!!!!
    i recently refornated m machine an ut on systmwoks 05 an i used to ge those popups the way to disable them is to go into the options an select the firewall options in the internet security menu..an look at the part thats called "program componant monitoring" an untick that....that should sort u out.
  7. Derelict
    Derelict What's a Dremel?
    29 Jan 2005
    Just turn off Norton's "Internet Worm Protection" within Norton Antivirus and you should be fine. :idea:
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    your router (if you have one) should stop most other stuff, and you can also use the windows firewall instead.
  9. Henchman:crg
    Henchman:crg What's a Dremel?
    9 Feb 2005
    I gave up using Norton, just caused too many problems.
    Try AVG for anti-virus and ZoneAlarm for firewall. Also works out cheaper, and they are much better products.
