Not able to upload images
Discussion in 'Feedback & Suggestions' started by Osgeld, 16 Nov 2019.
  1. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    Dunno what changed but whenever I try to upload an image I get this message
    PGTDESIGNS likes this.
  2. PGTDESIGNS
    PGTDESIGNS What's a Dremel?
    13 Nov 2019
    The same message I get..also size message. Tried in various browsers various size files but the same problem. This is not a "minimum" post problem as the message varies. There is a definite problem..
  3. GeorgeK
    18 Sep 2010
    @MLyons - is this an 'image size' issue or a 'new user' issue? Or just a 'general issue' issue?
  4. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    I have tried reuploading images I have already posted with the same results so its not size
  5. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Think I've worked out the issue. I'll get on to it now.
    EDIT: Think I've fixed it. Please try again
    GeorgeK likes this.
  6. PGTDESIGNS
    13 Nov 2019
    Like a charm...Thx :)
    MLyons likes this.
  7. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    Yes whatever you did seemed to resolve the issue, thank you
    MLyons likes this.
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Necro bump, I am getting this error now, tried Firefox, Chrome & Edge (argh), same message, doesn't appear to be anywhere near my quota.
    Is it me or has Doge broken something?
  9. wolfticket
    19 Apr 2008
    Same as of a couple of days ago. Tried various file sizes and types.
  10. MLyons
    3 Mar 2017
    I've applied a temporary fix for now. I'm sorting out something permanent now.
  11. Fingers66
    30 Apr 2010
    Thanks, it's working now, good luck on your permanent fix.
  12. MADPC
    MADPC Minimodder
    10 May 2020
    maybe is too big try to reduce it with JPG compression.
  13. wolfticket
    19 Apr 2008
    Unless I'm missing something I think this is happening again.
  14. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    its never fully gone away, the other day I uploaded a bunch of images, all the same size all same resolution and one out of however decided it was "too big"
  15. MLyons
    3 Mar 2017
    It's due to a space issue on the server and we can't expand it until we get the new servers which will hopefully done in the next few weeks. At this point I'm combing through the server looking for anything that I could potentially delete but I've used up most of my tricks previously.
  16. David
    7 Apr 2009
    Old Doge has no new tricks?
    There's an idiom in there somewhere, but I'm just not seeing it... :lol:
  17. MLyons
    3 Mar 2017
    The new trick is upgrade to two 2 x 64 core EPYC servers with 256GB RAM and 24TB of NVMe storage each. Issue is they're not in the data centre yet. How about I delete old media and users at random to free space :p:
  18. enbydee
    enbydee Minimodder
    10 Jul 2014
    Just 50% of them.
  19. David
    7 Apr 2009
    Half Doge, half Thanos?
    Argh!
  20. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    1: Any image file older than x days gets backed up to an off-server storage space / tape / clay tablet
    2: Each of those files gets re-encoded one by one to an image a fraction of the size (e.g. 1/4 or 1/8) and at a lower .jpg percentage
    3: Original file deleted off live server, teenified file renamed to original filename
    4: Move onto next image
    5: When new servers get mirrored over, teenified files can be replaced with originals again.
    Could get fancy by skiping files that are already below X kb or YxZ resolution to avoid avatar massacre.
