Windows Not Being able to save Jpegs and gifs
Discussion in 'Software' started by Death, 21 Oct 2003.
  1. Death
    Death What's a Dremel?
    21 Oct 2003
    For some odd reason in the last couple of weeks i cannot save jpegs, and gifs off the internet instead the only option im given is to save it as a BMP
    can anyone help me? :worried:
  2. Kermet
    Kermet [custom title]
    18 Feb 2003
    If the only option is to save as 'untitled.bmp' then it is a bug in IE (constult MS Knowledge base for more details), just clear you cache/temp files and all will be back to normal...
  3. Death
    21 Oct 2003
    So just clear my temporary internet files?
  4. Supercool
    Supercool Gone.
    31 May 2003
    Yeah.
    You can set your browser to clear your cache everytime you close it so you don't get this problem.
    It is possible to save as something other tham a .bmp though, you just change the extension on the end of the filename when you save it (although I think it makes .gif's lose their animation)
