Modding Not enough power
Discussion in 'Modding' started by Ryu_ookami, 29 Nov 2006.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    I've hooked up 2 car LED strips that are meant to run from a cigarette lighter socket in a car. I've put them up so that they will run as HDD LEDs but they're not getting enough power as they should be running off 12v.
    Is there any way or does anyone know of any way to make them run off the HDD header but still draw the amount of power they need without damaging any components.
  2. ARM
    ARM Minimodder
    15 Sep 2004
  3. Ryu_ookami
    11 Mar 2004
    I don't think i've explained what i've actually done very well give me a little time to go get a web cam and i'll post a pic here
  4. DougEdey
    5 Jul 2005
  5. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    surely you could do it using a transistor?
  6. Ryu_ookami
    11 Mar 2004
    ok here is what i have at present
    the leds are both meant to run from the same cigarette lighter socket so i figured that both together should be able to run from the same 12v off a psu and they do however what i want is for them to run from the hdd header and they do but they draw so little power that only one of them lights up and even then barely
    hope that explains it a bit better
    the single white wire on the on/off switch goes to the white wire on the HDD header connector then 2 wires (one from each of the leds) goes to the red wire. the other two wires (again one each from each Led connects to the on/off switch)
    the on/off switch bit works fine and if i connect them to the 12 volt rail of the psu they work fine its literally as far as i can see a way of making them draw the power from the 12v of the psu but only activating when the hdd is read that I need its not a matter of a seperate led for different drives. both leds are meant to work at the same time when any of the hdds are readitten to etc. also my electrical knowledge is almost nil mostly trial and error until i get it to work most of the rest of the electricals for the mod are done or i know how to do them but this is the first time i've linked anything i was doing to try and run directly connected to the mobo.
  7. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Of course you could do it with a transistor but you would need many transistors to drive all of those LED's
  8. Ryu_ookami
    11 Mar 2004
    above link fixed sort of for some reason its showing the picture rather than the link.
  9. Ryu_ookami
    11 Mar 2004
    ::cough:: ::bump:: ::cough::
    Still stuck...
