Modding Not seen this done yet!
Discussion in 'Modding' started by Shinobi, 23 Feb 2002.
  1. Shinobi
    Shinobi What's a Dremel?
    23 Feb 2002
    I have to say that the majority of my current mods follow Macro's own Lian Li PC60, I so far have stealthed the drives, and cut faceplates for my floppy and USB hub complete with fibre optic. So a big thanks to Macro!
    Now I have another idea that I have yet to see done anywhere else, yet.
    As i have a USB hub sitting in one of the 3.5" bays, that little flap at the bottom hiding the original USB ports is somewhat redundant. My plan is to remove the USB gubbins and replace them with a nice backlit single line LCD. I can then use this to display anything i like!
    What do you think? Macro fancy havin a go at it?
  2. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Wouldn't that be a little low on the case to see? I would have thought so, unless the case is up on your desk with your monitor.
    Not that I want to discurage you or anything ;) . I'm sure it would look great. :)
  3. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    my case is up on me desk and i can see the usb panel thingy fine :) altho it doesnt work, does ANYONE know how to wire these bitches up?
  4. Cool Hand
    Cool Hand King of the park
    21 Nov 2001
    a one line vf display would look sweet there (if there is such a thing)....
    im going to try placing my fan control switches there in my pc 68...and have the leds for them in another location...
  5. Geek
    Geek What's a Dremel?
    21 Nov 2001
    You'd be scrolling a lot - are you sure you want something that busy-looking on your desk? The main reason I like the larger LCDs/VFDs is that you can put fairly static data up and leave it for a while.
    Just my $.02.
    Gordon
