Electronics not working ahhhhh
Discussion in 'Modding' started by kh15, 3 May 2004.
  1. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    i'm trying to wire 2 blue 5mm leds for a mod, i'm soldering them in a parallel so i dont have to use any resistors
    this is how i'm doing it...
    5v, +, -, +, -, ground
    each led should be lighting up because they both should be getting 2.5 volts but their not liting up! help?
  2. kidron
    kidron What's a Dremel?
    26 Jul 2003
    the leds are still working?
    use a battery to test them, i use the ones that motherboards use
    it is really easy to test them with that kind of batteries
  3. stoned penguin
    stoned penguin What's a Dremel?
    23 Mar 2004
    if you wire them in parallel they both get 5V so you prolly fried the LEDs already
    you have to wire them in series to make them get 2.5V each and not use resistors
    but 2.5V is low for blue LEDs, usually 3.8-4V
  4. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    I think you got Parallel and serial backwards.
  5. specialk
    specialk What's a Dremel?
    5 Feb 2002
    Also, you should ALWAYS use a current limiting resistor if the supply will fluctuate, regardless of the forward voltage drop. LEDs are non-ohmic and will draw much more current if they receive a higher voltage than they are rated for (= bad!). Wire them up in parallel (not series as how you described you did) and put on a current limiting resistor.
    -special [k]
  6. kh15
    10 Mar 2004
    this is what i'm doing
    why wont it work i'm doing what you guys say and i have read guides on the internet and i'm pretty sure its all right and yes the leds do work?
  7. kh15
    10 Mar 2004
    [cough]bump
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    As the stoned penguin has said, 2.5V is too low for blue leds. They need about 3.6V each. So follow specialk's advice... :read:
