Other Now its built
Discussion in 'Hardware' started by chrispy61, 19 Sep 2010.
  1. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
    So my PC is finally up and running all drivers ect installed, should i set a restore point or somthing simalar i case of future misshaps??
  2. Teelzebub
    27 Nov 2009
    I always do
  3. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    Having a clean installation backup is never going to hurt, I would say go for it.
  4. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    I have an older small hard drive (250gb) and I first installed windows and a few other things onto that. I then plugged in my f3 1tb and converted it into a raid 1 array. I then broke the array leaving me with two single identical installs. I'm now running off the f3 (after extending the windows partition) but if anything goes wrong I can format it and use the spare drive and remake the array (then destroy it) in a couple of hours. I also copy any important files to an external drive.
    If you've got space for a back up then its a good idea it's not going to cost anything, except maybe some time, and if you ever have cause to need it you will be glad you did.
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I never bother. Reinstalling W7 on my SSD only takes around 15 minutes so I don't see the point of faffing around :)
  6. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I have to agree with this statement and I have an external HDD with the drivers for my things like mouse and keyboard, player profiles for COD4 and plus other drivers
  7. favst89
    23 Jul 2010
    Thats true if I had an ssd it would be fast enough not to bother but with a raid backup I've got windows, office, steam and some other games already installed. It does save time and I can use the computer while its creating the array so it allows me to have everything ready and usable very quickly.
  8. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    This. Plus, I've always seen system restore as a liability. You can't imagine how many times I've seen virii get backed up in the system restore file and continue to propagate from it. Not worth it, in my opinion.
  9. Ph4ZeD
    22 Jul 2009
    It was worth it back in the day when reinstalling Windows took 3 hours plus laboriously changing driver floppy after floppy to use all your devices. A fresh W7 install works out the box completely for me. It makes more sense to format, which ensures any software issue will sail away (or virus) and start afresh.
  10. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    One thing i do have is a spare large-ish usb stick with all of the programs i use regularly which have to be downloaded. Everything such as what people have been posting in the Free software you cannot live without thread. Saves a hell of alot of time and hassle when reinstalls come around. You dont even need to keep them up to date since virtually everything will tell you there is a newer version the first time it is ran.
