Windows NTFS.SYS corrupt or missing
Discussion in 'Software' started by malMethod, 14 Jul 2003.
  1. malMethod
    malMethod What's a Dremel?
    9 Jul 2003
    i get this error message. im guessing i have to reinstall windows huh?
  2. Hargle
    Hargle What's a Dremel?
    13 Oct 2001
    Can you access a recovery console? If so you should be able to attempt copying the original ntfs.sys file from the installation CD. Worth a try before doing a complete reinstall I would say.
  3. malMethod
    9 Jul 2003
    whats a recovery console? sorry im a newbie. i have winxp pro on the machine right now, but dont have the cd for it.
    however, winxp home will be here in 2 days.
  4. Hargle
    13 Oct 2001
    I've not got huge levels of experience with XP but as far as I know there's a recovery console, which is DOSlike and allows you to do some low level maintenance when the system isn't booting right. If you lack experience and an installation CD it's probably a good idea to contact a friend who show you exactly what needs doing.
  5. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    to get to the consol you need your xp disk. boot from the disk and watch the prompts. one if them is for the recovery consol. oh yea i have a good amount of dos expierence and i find that the consol cant do half the things you need. save your self the pain and reinstall.
  6. 554
    554 What's a Dremel?
    22 Jun 2003
    also check all yuopr ide connectiuons ide and power
    and also most other conenctions
    i get this sometimes
    and a quick pushign oif all the connectiosnm seems ot fix it
    also try makign sure your ram is settled ok
  7. malMethod
    9 Jul 2003
    turned out i had a bad stick of ram. i got windows reinstalled now. thansk for yall's effort to help:)
  8. corvette
    corvette What's a Dremel?
    27 Nov 2001
    i just was about to post ive had this prob on 3 different machines and it was bad ram
    so yea hope everythings runnin sweet now
  9. Froggy
    10 Jun 2003
    hmm my ram isnt bad.
  10. corvette
    27 Nov 2001
    just coz the PC runs dont mean ur ram is bad im still runnin 1 of the 3 machines with the bodgey ram at the mo and it still runs and i only get the msg every 3-4 reboots / startups
    ive changed it with ram from my main machine and it dont do it so all i need is 60$ and i got me a stick of 512Kingston
