NTFS to FAT32
Discussion in 'Hardware' started by batsman, 12 May 2002.
Thread Status:
Not open for further replies.
  1. batsman
    batsman the quiet one
    14 Nov 2001
    any one know any free/time limited apps that will convert a drive from NTFS to FAT32 without loss of data?
    thanks for any help
  2. wip3out
    wip3out What's a Dremel?
    8 Jan 2002
    I'm pretty sure it's not possible. :(
  3. Linkitch
    Linkitch What's a Dremel?
    11 May 2002
    It can be done with a program... can't remember wich program though... sry...
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    windows 2000 does it for all i know...i think under tools but im not too sure as all my drives are ntfs...
  5. The Punisher 2000
    The Punisher 2000 What's a Dremel?
    21 Apr 2002
    How about FAT32 to NTFS anyone know how to do that. My dad has a computer but all he uses it for is his excel sheets and data stuff like that. How would he be able to change his filesystem to NTFS or is it possible???
  6. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    Try a program called partition magic 7, i believe it can convert HD partitions BUT you would most definatly lose all the stuff on ur HD.
  7. wip3out
    8 Jan 2002
    you learn something new everyday at bittech....
  8. Shepps
    5 May 2002
    hehe :lol:
  9. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Not quite sure why you'd want to though....
  10. Shepps
    5 May 2002
    thinkin about it.........wudn't it be easier just to format it by using a win98 startup disk.....Using fdisk to delete the NTFS, then creating a new dos partition, then formatting using format to a FAT32...
  11. batsman
    14 Nov 2001
    thanks for the suggestions, but none of those would have been any good as i needed the data intact, and partition magic didn't work for some reason.
    in the end i have to load on xp move the data from the NTFS drive, format the Drive to FAT32 and then move the information back.
    thanks anyway
  12. GJUK
    GJUK What's a Dremel?
    10 Apr 2002
    going from ntfs to fat32 would only give you one major plus.
    its accessible in dos. so if your using the drive for major backups, and it knoks itself. you may stil have a backup of ur back up, if you get me.
    other than that, fat32 - slightly faster maybe in a few things.
    but ntfs overall is more stable.
    Jono
  13. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    fdisk will not always remove a NTFS partition.. the only two programs I know of that will convert NTFS to FAT is Partition Magic or System Commander.. (a very usefull tool)
    As far as converting fat to NTFS, NT, 2000, and XP come with a conversion util..
    Running NTFS on a local, single user PC is about pointless, and just creates troubleshooting headaches..
    -scoob8000
  14. Lazy
    Lazy Meow?
    13 Nov 2001
    Partition magic can do it and it won't format the hard drive either. However don't try to convert the partition you os is running off of. I found that this doesn't seem to work. :D
  15. batsman
    14 Nov 2001
    again thanks for the help but the problem is solved, can someone close the thread thanks
  16. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
Thread Status:
