Case Mod - Complete ⭐ NVC Build= No visible cables
Discussion in 'Project Logs' started by zak, 19 Apr 2018.
  1. zak
    zak Build Clean people, build clean
    18 Apr 2018
    I thought about that, the only problem would be the massive gap. Your saying a pvc pipe to fill in the gap?
  2. Cheapskate
    13 May 2007
    I'm saying find a pipe that matches the res diameter, and fill the space between res and panel.
  3. zak
    18 Apr 2018
    omg guess what i found?? I didnt even know such a thing existed, someone on reddit recommended it!!! I just ordered 2 sizes because i wasnt sure which would be correct size, and i will be soooo happy if it works. I ordered overnight so I should have it tomorrow.!!1
    can you believe there is an adjustable fitting? Where has this been all my life.
  4. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
    I dont know where you look first, so I post you on all the 3 thread I know you use ;)
    I have one of those.... Just a different length and from Thermaltake.
    Had a problem similar to yours a while back on my build, actually now when you mention it, I don't think I shared anything about that piece, sorry m8.
    You can see it here, screw it in from both ends and then there in the middle there is like 3 o-rings and an adjustable "nut" to tighten them with when you get the right length.
    I could seriously not fit my res and pump this way without, it's a very special type of fitting but it just works.
    Bear in mind, it can not hold up much weight, else it's going to compress on itself and slide downwards.
    I would imagine the Barrows are similar.
    Thermaltake fittings are pretty expensive in my opinion, but damn the quality is top notch on the pieces I have from them, can only recommend it.
  5. zak
    18 Apr 2018
    OMG how could you hold that info out? I thought we were best friends? :waah:
    Just kidding, I need it in the SAME spot, my res to pump, no way i can do it without! I cant believe that works, im so pumped!
  6. AT0MAC
    8 Jun 2008
    Yea sorry man, this is one of the many exotic pieces in my build, should probably have mentioned it - but I stumbled upon it much earlier in the process and kind of forgot about it along the way.
    I'm fairly sure it's this one I have, as far as I remember I needed something like 31,5mm length and this is the only thing possible to do that.
    Looks like the only place in the US I seem to find it is on Amazon
    Do have in mind they make a few models, different lengths, so get the right one ;)
  7. zak
    18 Apr 2018
    Ok this is Officially REALLY OFFICIALLY the final update.
    Expect pictures for final reveal on Friday, I need to take today and see if I can find or borrow a better than iphone camera, if I cant, oh well. Iphone X takes really good pictures in the light, it just suffers a little in real low light scenarios.
    So guess what? Im in love. I fell in love with that barrow (or bitspower makes it too) expandable/retractable G 1/4 fitting. It saved my ass, and fixed my leak, and my system is up and running! It took a previously difficult 2 hour fitting install at the reservoir, and turned it into a super easy, leak proof, 5 min install. I could not be happier with that fitting.
    Could not recommend to anyone any more than I am now. It is AWESOME
    The only problem I have now is GSKIL ram sucks. One of the sticks wont work. It has a mind of its own, and changes to whatever color it wants. Everything else works fine, all other lighting, including the other RAM stick, so I dont know what to do. I wish I could return it but its too late.
  8. zak
    18 Apr 2018
    there heeeerrreeeee
  9. zak
    18 Apr 2018
    Ok here are the final pics, i think it came out great, but I built it how i wanted it, so of course im going to like it..... I hope others do to, remember I went for cleanliniess first, no cables, transistors, cap banks etc. to be visible, and I wanted hidden lights and skulls. Thats what i wanted.
    Unfortunately I had to use an iphone....No DSLR. But I did go to alot of trouble to buy diffusers for some LEDs and also bought blackout paper for background. I did the best I could, and it sucks using iphone because the shots with NO outside light, all came out crappy, so I included only 1 shot with no room lighting... But the pics dont do it justice, it looks awesome in real life.
    Anfield and arduum like this.
  10. kim
    kim hardware addict
    10 Jan 2016
    :thumb: really clean and nice build, that's a fact it would deserve a photo shot with a better light, I'm sure it looks more awesome in real
  11. Dietec
    Dietec Minimodder
    2 Oct 2017
    Very clean and professional looking!
  12. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Nice job man, love the way it looks with everything shielded
  13. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Jaw droppingly stunning man! :rock:
    is that even a word? this mod deserves a new word :D :clap:
  14. Cheapskate
    13 May 2007
    That came out great. :D Nice and clean.
    Yeah, I knew about those fittings..I always push for more modding.
  15. Colossous
    Colossous Minimodder
    28 May 2007
    Wow - i've been away a long time - glad to see some old faces still here and what a build dude :rock:
  16. zak
    18 Apr 2018
    thanks! you must have been catching up looking at all the builds :)
