Some valuable frames with successive driver releases here! How do you compile these results true_gamer?
I play on a full 32 player map, and just run and gun down anything in my way, running through every nock and cranny. So the results will give you a average gaming FPS of 100FPS which is just insane with the game maxed out at 2560x1600.
I am getting around 100fps now at stock on my 2gb card running it at 1920x1080. I have noticed though that the previous overclock I had saved in MSI Afterburner which was stable is now not stable so need to, do some tweaking to see what will be stable using these new drivers.
2560x1600 has nearly double the pixel count than that of 1920x1080. So I would expect a average of 50FPS with your single GTX 680 at my resolution.
301.34 Drivers are GTX 670 drivers which I modded to run on my GTX 680's. So as official drivers for the GTX 680, there is an improvement over the 301.10 drivers.
Just tried that level to see what it runs like with similar settings, bit frantic for me, had some fun though, seems AA is the killer, doesn't look to bad without AA actually, probably because of the small pixel size on the screen. Think the single GPU is not bad to be honest, really need to replace my £2 LOGIK mouse though. Code: Resolution 2560x1440 AA 4x 2x 0x Min 46 50 60 Ave 58 71 83 Max 77 122 125 Course I did not put the new drivers on, doh.
