nVidia 5200 and AGP 2.0
Discussion in 'Hardware' started by Flax, 4 Jul 2003.
  1. Flax
    Flax What's a Dremel?
    24 Jun 2002
    Can I run an nVidia 5200 (8x AGP) on a motherboard that only supports 4x? If it works what will the performance loss be?
  2. Guest-16
    Guest-16 Guest
    performance loss will be negligable, you get more performance difference from your ram timings/drivers i would have thought. AGP 8x is completely backwards compatible to AGP4x but NOT AGP2x cause AGP1.x spec is 3.3v which will fubar a 1.5v card.
