Graphics nvidia 5600 any good?
Discussion in 'Hardware' started by Ilya, 21 Aug 2004.
  1. Ilya
    Ilya What's a Dremel?
    21 Aug 2004
    I have pentium 4 3.4
    1gb corsair platium
    and 5600 256mb nvidia
    http://www.newegg.com/app/ViewProductDesc.asp?description=14-130-191&depa=1
    i bought this system for gameing only and i messed up with vid card i hear alot people say that that video card has low fps !
    will i be able to run doom 3 smooth? on high settings?
    or
    should i upgrade to 6800gt?
    if i uprade to 6800gt and i overclock it to 400/1100 *ultra speed*
    will it run good with stock fan? or i will have to get extra fans?
    PS: i have no liqued cooling
  2. henson0115
    henson0115 Banned
    16 Apr 2004
    the fx5600 is **** and so is the fx range except the 5900 go for an iti you can get a 9800 for cheaper than that i brought a 5600 and now i wish i didnt i can get better from a ti 4200 and they are quite old
  3. Ilya
    21 Aug 2004
    I'm going to for 6800gt then!
    what about over clocking?will stock fan do the job or i have to buy another?
  4. henson0115
    henson0115 Banned
    16 Apr 2004
    o/c which 6800 or 5600
  5. Ilya
    21 Aug 2004
    6800gt to ultra speed 400/1100
  6. henson0115
    henson0115 Banned
    16 Apr 2004
    it should be fine but if you had the money you could always add watercooling to your system
  7. Ilya
    21 Aug 2004
    no need for water cooling i have about 5fans in case + very huge processor fan i think it called volcane 7+ thermaltake!
  8. henson0115
    henson0115 Banned
    16 Apr 2004
    stock fan should be fine on the 6800 then if not you could always get something else fan wise not really that expensive
  9. Ilya
    21 Aug 2004
  10. henson0115
    henson0115 Banned
    16 Apr 2004
    your better of trying stock fan fisrt as the stock fan will be pulling air from your computer so if you want cool air going in to your card thats not the way about it depending on which way you have that blue fan card so stick with stock and if you have any probs pm me and ill link you a good 6800 fan ok
  11. WORMAGE
    WORMAGE What's a Dremel?
    19 Aug 2004
    5600xt
    i bought a 128mg 5600xt got it home and my old geforce 3 ti200 64 beat it on 3dmark 01se by abount 600points
