Graphics Nvidia 680 - Advice please
Discussion in 'Hardware' started by mattbailey, 28 Jul 2012.
  1. mattbailey
    mattbailey What's a Dremel?
    26 Dec 2009
    I want (read need!) a 680. Its going to replace a 5870 - and I intend for it to last 3-5 years.
    I have a 24" monitor at 1920*1200 and am nearly addicted to BF3
    I am currently looking at:
    1) 2GB EVGA GTX 680 SC Signature 2, GPU 1097MHz / Boost 1163MHz, 6208MHz GDDR5 - 5 year extended warranty for about £30 extra
    2) 2GB Gigabyte GTX 680 Windforce 3X 28nm, GPU 1071MHz / Boost 1137MHz, 6008MHz GDDR5 - 3 year warranty
    3) 2GB MSI GTX 680 Lightning, GPU 1110 / Boost 1176MHz / 6008MHz GDDR5 - 3 year warranty
    4) 2GB Zotac GTX 680 AMP Edition, GPU 1110MHz / Boost 1176MHz, 6608MHz GDDR5 - 5 year warranty free upon registration
    Your thoughts please?
  2. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    First of all never expect something to last, we can't predict the future so don't know what will happen in a few years. a 680 is a great card but more than what's needed for 1920x1200 with the current games.
  3. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    the lightening by a long shot!!
    its a custom PCB with improved vrms and most components!! itll easily overclock more than air cooling can handle and lets be honest it looks the best!! ;)
  4. Guest-44432
    Guest-44432 Guest
    Why hasn't no one told you to get a GTX 670 instead?...
    The performance is about the same, and yet some 670's OC better than some 680's.
    So save yourself the £100 and get a GTX 670. :)
    Pookeyhead likes this.
  5. jakobfrimmel
    2 Jan 2011
    well he did ask for best gtx 680 :p but yea hes right a gtx 670 or a hd7970 would be a better choice...
  6. sandys
    sandys Multimodder
    26 Mar 2006
    An overclocked 670 is about the same as a 680 but a 680 overclocks too.
    Buy the cheapest 680, they all seem to overclock in similar ballpark.
    Of the ones listed what differentiates then, does the MSI enable higher voltages?
  7. Booti
    Booti Minimodder
    17 Jan 2011
    From what i have seen the Zotac seems the best choice. The extra RAM speed and fastest clock (with the MSI) make them very impressive.
    If it was my money though, i would get the Zotac 670AMP instead. Beats a stock 680 by a long way and saves you £100+
    (if it gets too slow later, SLI it :))
  8. sandys
    sandys Multimodder
    26 Mar 2006
    How are you saving 100+ ? difference between highend 670 and low end 680 is bugger all, the high end 670 will be as fast as a stock 680 if not a touch faster sure (beats a stock 680 by a long way is probably overstating things a bit) but that is glossing over the fact the 680 overclocks too.
  9. rollo
    rollo Modder
    16 May 2008
    670 overclocked performs as a stock 680 does in most games main exception is bf3.
    Every 680 will hit 1100mhz core and +250 MHz on ram without issue though
    I'd buy evga every time, the normal evga 680 is fine and getting cheaper.
  10. Booti
    Booti Minimodder
    17 Jan 2011
    Sorry, ill stand correct. Prices have come down a bit since i last looked.
    I was comparing the Zotac 670Amp to the listed cards, so up to an £80 saving then (depending on where you shop)
  11. sandys
    sandys Multimodder
    26 Mar 2006
    Yup it was £380 last week for an EVga 680, I almost bought a second, so not even as much as 80, a Zotac 670 AMP is not £300, if you were going for single fastest Nvidia card you may as well get a cheap 680 and take your chances on overclocking it rather than a pre overclocked 670, though admittedly being based on the same silicon you can make the same argument for the 670 and buy a cheapo one of those.
    If you were going to go SLI then two 670 makes sense for the cumulative cost saving and little performance deviation due to SLI overheads.
    My 680 plays quite nicely at +192 which is 1250 typical with boost though some times goes a touch higher and the RAM does +600, its just a boggo one, perhaps I am lucky?
  12. Mrmelon98
    Mrmelon98 When's a Dremel?
    26 Jan 2012
    I have to agree, the lightning is best
    DAMN i quoted the wrong post:wallbash:
    The point is i would choose the lightning OKAY??
  13. Shirty
    18 Apr 1982
    In fact, if Tweaktown's "review" of the 660 is anything to go by, I'd suggest saving quite a few pennies and going for that in a fortnight when it's released.
    Than add another down the line if things change.
  14. FifteeeCal
    FifteeeCal What's a Dremel?
    11 Jun 2011
    There's barely any difference between a 670 and a 680, none when overclocked, I'd save a bit of cash and go for 670 or a 7970, if you really want to spend more then a 4GB GTX670, only if you;re planning on getting a higher res monitor at some point though.
