News Nvidia and Asus announce world's first 360Hz monitor
Discussion in 'Article Discussion' started by bit-tech, 6 Jan 2020.
  1. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    From the Guru3d article:
    Emphasis mine. 3440*1440*10*3*200*10/8 = 37,152,000,000
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    My bad, however the same issue will also apply with that 38" LG as it is also 10 bit (so you still throw away either 10bit or 175hz).
  3. monty-pup
    monty-pup Minimodder
    8 Apr 2018
    Is this why they sell it as 144hz ... and you can ‘overclock’ it to 175hz (but lose some bit) ... ?
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    Presumably yes.
  5. monty-pup
    8 Apr 2018
    Maybe that isn’t such an issue for me ...
    If I’m playing a multiplayer FPS like CSGO on such a big screen I’d turn down a few things to maximise the fps and overclock it.
    then if I’m playing other games and want the best colour reproduction I’d downclock it?
  6. edzieba
    14 Jan 2009
    No. The 10/8 is due to the LVDS signalling protocol used for DP using a 10:8 encoding scheme for forward error correction: for every 8 "real" bits you want to send, 10 bits are transmitted over each channel (8 data 2 parity essentially). Hence to get from the "real" bitrate required to the raw channel bitrate used, you need to multiply by 10/8.
    True, but it's also a basic fake-HDR panel (SDR panel with hDR colour space squished into pointlessness), rather than something that could take any real advantage of 10bit colour depth with enhanced contrast.
    According to TFTcentral's panel database, the LG 38GL950 uses the LG Display LM375QW2 panel. That is an 8-bit panel, so in 10-bit mode it's using FRC rather than native 10bit pixel driving. Combined with the lack of HDR, and the pretty low likelihood any given game will be using high bit depth for anything other than HDR (i.e. nobody bothers to master for 10 bit SDR), no real loss from 'dropping' to 8 bit.
  7. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    @Anfield (post: #14)
    Correct the attribution of the quote you used please, that was not said by me.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    No clue how that happened since I never typed your name and it had the autogenerated link stuff and everything?
    Anyway, it has been fixed.
    Mr_Mistoffelees likes this.
  9. Mr_Mistoffelees
    26 Aug 2014
    Thank-you.
Tags: Add Tags
