News Nvidia announces RTX A6000 and A40
Discussion in 'Article Discussion' started by bit-tech, 5 Oct 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
  2. RedFlames
    23 Apr 2009
    TBH I expect it to come in closer to the RTX6000's RRP [$6k iirc], with an A8000 with a ridiculous amount of VRAM to come later. If the new one was intended to be the range topper i think nv would've numbered it accordingly.
    I mean it still ain't gonna be cheap, and if the price bothers you even a teensy little bit you're probably not the target audience for it, but i can't see it being the £10k that the Tesla A100 is.
  3. IamSoulRider
    IamSoulRider Minimodder
    24 Aug 2016
    Nvidia seem to have killed off all their branding except Geforce. Quadro - Gone, Titan - Gone, Tesla - Gone (Although understandably).
  4. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    @1:03 something looks familiar
  5. RedFlames
    23 Apr 2009
    One thing that has me slightly perplexed is the 2 [what look like] threaded holes at the end of the card... wonder if it's for some kind of stabilisation bracket or something, but they're present and in the same place on both cards
    EDIT: Another minor annoyance but... the nvidia logo is gonna be upside down when you put that card in most systems.
  6. Paradigm Shifter
    10 May 2006
    Yes, that is so a bracket can be attached to provide the card extra support. Different length/height and/or adjustable brackets can be attached, depending on the case. Years ago I picked up a refurbed quad GPU server and the cards all had extra brackets attached.
    All the rackmount cases I've seen would have the cards vertical, rather than horizontal. It's interesting that they're a single 8-pin, though. The RTX8000's were dual 8-pin. The apparently crazy power requirements for "consumer" Ampere makes me wonder how these stack up.
  7. RedFlames
    23 Apr 2009
    They're not PCI-E 8-pin...they're EPS [CPU] 8-pin
    Thought so, and i've seen cards with that kind of thing attatched... just first time I've ever noticed those holes...
  8. Paradigm Shifter
    10 May 2006
    So 235w (continuous) max, rather than 150w. OK, that makes a little more sense. Even so that's still max 310w. Like I said, the RTX8000 had two PCI-E 8-pin, so max was 375w... and those suckers could easily pull that much down, as well if loaded right (or wrong...).
    To be fair, often in the past they were just a reinforced metal frame strapped to the PCB, rather than integrated into the shroud.
Tags: Add Tags
