Graphics nvidia forceware 91.31
Discussion in 'Hardware' started by Pookeyhead, 8 Jul 2006.
  1. Pookeyhead
    30 Jan 2004
    How utterly crap is nVidia's new "Control panel" in the new Forceware drivers??
    I can't believe it. It's removed all my profiles for games without prompting, it no longer shows the overclocking options if you have the coolbits registry hack.. it's childish, annoying, and to me, just seems like an extension of every other annoyingly useless windows help file.
    What on earth are they doing???
    Old drivers going straight back on.
  2. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Sounds like catalyst :hehe: But seriously no overclocking panel ? What is the world coming to ?
  3. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    there is an option to enable normal panel mode
  4. Pookeyhead
    30 Jan 2004
    that's well hidden then. I'm back on 89.... whatever. I'll have a play later.
  5. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    To get back to the old control panel:
    Go to display properties > Settings > Advanced > Name of gfx card > Control Panel User Interface > Classic nVidia control panel
  6. Max Tractor
    Max Tractor Minimodder
    15 Jan 2006
    Yup, new control panel is crap, happily found the classic option
  7. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    The thing that anoys me is that every time i turn my pc on, it kindly informs me that i dont have SLI activated. Well of course i don't! I only have one gfx card ffs!
  8. Tim S
    Tim S OG
    8 Nov 2001
    There is the option to turn on coolbits - I've used it in all reviews using the 90-series drivers.
  9. Drastik
    10 Jan 2002
    ya the sli warning is dumb...how do i enable coolbits
  10. Pookeyhead
    30 Jan 2004
    What about that SLI warning? I'm not putting it back on until I know I can disable that. Anyone done it yet?
  11. Fr4nk
    12 Mar 2005
    A quick google found:
  12. Max Tractor
    15 Jan 2006
    SLI pop up is a pain, even more so when you miss the x and a page tries to load
  13. Mr.ME
    Mr.ME Minimodder
    22 Jan 2006
    the 91.30drivers are a pain in the a**
    http://www.hardocp.com/
    Crashing NVIDIA WHQL Drivers
    Hopefully not many of you will fall victim to this due to the new series 5 NVIDIA nForce motherboard product just now getting to market, but is something to be aware of. We have tested two nForce 570 SLI chipset motherboards here recently that do not take well to the latest v91.31 WHQL video card drivers when using the latest v9.16 WHQL chipset drivers from NVIDIA. In fact, using these v91.31 drivers with the nForce 570 resulted in crashed operating systems and corrupted hard drives. It seems that the problem may not stop there either. One source in Taiwan mentioned that the problem might extend to the Intel 955X chipset as well.
    nVidia Forceware V91.31 has compatible problem with nForce 570 SLI and Intel 955X chipset. Please downgrade to nVidia Forceware V84.21 or try the latest V91.33beta.
    The v91.33 Beta video card drivers are available directly from NVIDIA.
    From our internal testing, it seems as if the v91.33 beta drivers do in fact fix the severe crashing issue.
  14. Hazza
    Hazza What's a Dremel?
    25 Nov 2003
    well im glad i read this! I was just about to update to 91.31! *phew*
  15. Pookeyhead
    30 Jan 2004
    I'm STILL arsing about with this.
    Right.. the latest problem is the taskbar icon. I've set this to be disabled because I dont want it, and everytime I reboot, it's back, and enabled in the driver window.
    Anyone else got this problem? I dont want a bloody icon in my systray!!
    Why are Nvidia being so bloody stupid?? Did they not get any feedback from people before releasing this latest driver? It's done NOTHING but piss me off since I installed it. If I take it off, Steam keeps bugging me that I've not got the latest drivers... Arrrghhh!!!
    Seriously considering going ATi if this doesn't get resolved.
  16. Tim S
    Tim S OG
    8 Nov 2001
    Have you tried 91.33 on nZone?
  17. Pookeyhead
    30 Jan 2004
    On my way now... Haven't even checked since I installed this, as I've been too busy trying to get it work as well as the 89.xx drivers... which were flawless IMO.
    I'll install it and see. Cheers :thumb:
    [edit]
    That sorted it.
  18. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I did 91.31 a couple of days ago and since reverted back to the 8x.xx. as soon as i had installed the 91.31 my it's start getting nv_driver bluescreens with my 6800GT. sure the card was OC's but not any more then it had been with the 8x.xx's for months before hand with no problems.
  19. TMM
    TMM Modder
    12 Jan 2004
    91.31 is faster on my 7600GT then 8x.xx in just about everything.
