News Nvidia G-Sync unveiled as stunning new monitor syncing tech
Discussion in 'Article Discussion' started by Meanmotion, 18 Oct 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. LordPyrinc
    LordPyrinc Legomaniac
    7 Mar 2008
    As long as they aren't ridiculously expensive, I'd consider buying one. It's about darn time that they took a look at fixing this problem. I've always been annoyed at having to chose between great looking cut scenes/gameplay with no tearing or smoother gameplay with tearing on certain titles. I was getting tearing in Metro LL last time I played it, but when I turned v-sync on, I got a detectable performance hit. That's probably why I haven't fired the game up lately. Even small amounts of tearing annoys the heck out of me.
  3. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I can see this as a Good Thing but unless the technology is made available to AMD and Intel I hope it doesn't catch on.
    This sort of thing should be for the Greater Good.
  4. Tim S
    Tim S OG
    8 Nov 2001
    Surely it's for AMD/Intel to reverse engineer, not Nvidia to give out for free?
    It is something that has been a problem for years and, by the sounds of what's been written in the live blogs, something that Nvidia has being trying to solve for years.
    EDIT: That said, it seems Nvidia is open to possibly licensing the technology to other hardware vendors.
  5. lp rob1
    lp rob1 Modder
    14 Jun 2010
    /grammar nazi :D
  6. Meanmotion
    16 Nov 2003
    Cheers. Fixed.
  7. jcb121
    jcb121 What's a Dremel?
    27 Dec 2009
    sown*
  8. XXAOSICXX
    XXAOSICXX Minimodder
    20 Apr 2011
    "control of the montior's framerate"
    er......
  9. forum_user
    forum_user forum_title
    4 Jan 2012
    'bout bloody time!!
    \o/
  10. theshadow2001
    3 May 2012
    Oh yes. The want is strong.
  11. Guest-16
    Guest-16 Guest
    We've got a 24" monitor coming with it early next year.
  12. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Um, ok. Weird product. I would have to buy a new monitor and a new gpu. I'll pass.
  13. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    As I run 3 displays I won't be replacing anytime soon this technology, however cool is of limited use to me. Now, if they throw it on an oculus...
  14. wyx087
    15 Aug 2007
    But what panel is it?
    I'd be interested in this technology, but would never want to look at TN screen again in my life. Problem is most gamer monitors are TN panels and marketed based on TN panel's lower refresh rate.
  15. SAimNE
    SAimNE What's a Dremel?
    23 Oct 2012
    i hope amd starts using this with their apu dual graphics.... they've shown a lot of progress on micro-stuttering recently, and now the only real problem with an apu crossfire is the variable framerates.... if they can mimic this the apu will completely dominate the low-mid market on price-performance o.o
  16. richms
    richms What's a Dremel?
    24 Mar 2003
    Im more interested in if this will allow seemless shifts between 24/50/60 Hz modes for when playing video.
    Mind you, I thought that changing the refresh rate on the fly was supposed to come with displayport...
  17. Guest-16
    Guest-16 Guest
    You're rating all TN's the same - they aren't. Modern TN's are practically the same as eIPS in many facets, but you won't get 120+Hz from an IPS without clear problems.
    It does change refresh rate on the fly, and with GPU accelerated video it should sync the video frame rate to the monitors. I don't know the limitations though. EDIT: 2D refresh rates don't go below 60Hz, but it depends whether they class GPU accelerated video as '2D'.
    I just heard Nvidia is making a modification kit for VG248QEs available by year end as well ($175). It's a custom Nvidia chip (with what looks like frame buffer), which is why it's not a cheap thing, and also why AMD/Intel won't have it without some serious reverse engineering I guess.
  18. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Didnt triple buffering solve this problem, only that many developers werent implementing it in game?
  19. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    I understand intel/amd can reverse engineer it most probably but how about onpliance? What if I had an nvida.and switches to AMD would that mean I have to replace.my.monitors as well?
  20. DrTiCool
    DrTiCool Minimodder
    14 Jul 2010
    any word that it might be implemented into TVs as well?
Tags: Add Tags
