Hardware Nvidia GeForce GTX 480 1,536MB Review
Discussion in 'Article Discussion' started by Claave, 27 Mar 2010.
  1. wyx087
    wyx087 Multimodder
    15 Aug 2007
    soldering iron are at 300c and they hardly melt the very cheap PCB's (think ordering single one-off for £50 at PCBtrain). so i'd say nVidia multi-layered PCB can withstand more than 300c no problem.
    5870 are found to have spaces for extra power phase and 8+6 pin PCIe power connector spacing. so it is very likely when chip production picks up.
    about Dirt 2 and STALKER, is the card's thermal performance not bad enough? why keep picking holes in this product?
    i can't wait for Bit-tech's architecture in-depth look, im sure there's a reason for it being so hot/power nom nom.
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Its not bad enough if the "good" or "decent" results are achieved by excluding information or cheating the consumer out of something that they expect from a $500 product, and it's worse when a Tech Journalist gives them a bye and lets the product look better than it is.
  3. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    thats pretty disappointing considering all the hype that was being thrown around.
  4. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    No need, everything is explained on semiaccurate. As much as you should take anything Charlie says with a grain of salt (or a handful), he has been pretty spot on about everything Fermi related for months. In nVidia's defence, it wasn't all their fault, but they made some stupid decisions, attempted to fix some problems with the wrong approach, and at the end of the day I don't think their monolithic GPU strategy is such a good one.
  5. RotoSequence
    6 Jan 2004
    The short Version of what Charlie has been saying for the past few months is that the combination of TSMC's 40nm process (which is rife with trouble, as the 4770 was born just as a test article for this process) and the massive die Fermi has made it extremely difficult to manufacture, even with two respins (re-working the metal layers of the chip). ATI engineered around the problem with the 5xxx series, while Nvidia largely whined about TSMC's inadequacy and brute forced their chip to functionality by cranking up the voltage to make the transistors switch. Add in the inevitable defects present in a 529mm square die and Fermi is the cut down result that we have today over what the chip was supposed to be.
  6. knutjb
    knutjb What's a Dremel?
    9 Mar 2009
    Nvidia released a new card and all I saw was a hot running power hungry overpriced 5870 yawn.....
    Are we sure its not another 8800 rebadge? C'mon Nvida, we waited this long to be let down, you could have done this to us six months ago and played the underdog and not the snob. I'm not a fanboy but your recent behavior, both rebadging and exorbitant prices, do nothing but justify buying ATI. I know the 480 SLI is pretty good but for a 1000! Ok what can it do with CUDA?
    The tides have turned again. I do hope Nvidia can get their act together, competition is good for us in lower prices. If I had the money today a 5850 Cross Fire looks very reasonable. Maybe now game programmers will stop stacking the decks against ATI. (ref. Batman et. all) I know, wishful thinking.
  7. HourBeforeDawn
    26 Oct 2006
    programmers didnt stack against ATI, they were paid, I mean funded to lol. Either way ATI is certainly maintaining the crown, which is good, it will get their budget up for more R&D and so on so this is all good in the long run.
  8. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    You'd melt a hole right through your motherboard and case if you even try and put 2 of these furnaces near each other as well as using half the electricity needed to power Manhattan :sigh:
  9. Guest-16
    Guest-16 Guest
    As far as I know Dirt2 was edited with the ini file directly not changed settings within the game, but I'll leave the guys to answer.
    STALKER doesn't allow AA or whatever because some technical reason I always forget, so the guys don't do it. Instead they ramped every option to the fullest so it looks as good as it can possibly get.
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    We'll be doing some testing on Monday to confirmm but if so we'll obviously make corrections. We tested by editting the .ini file of the hardware settings, explicitly forcing the Direct X version to 11. If the game has not recognised these new cards and defaulted to DX9, we'll obviously be retesting and will likely add a follow up article.
    Insofar as STALKER numbers - historically we've never tested STALKER with AA - just look back through the last year or so of graphics reviews. AA has typically killed performance in this game and was massively optimised for ATI hardware iirc, so we chose to review without - the 0xAA number speak for themselves though.
  11. Pete J
    Pete J Employed scum
    28 Sep 2009
    4GB of VRAM on a dual GPU card actually means you have 2GB effective. I'm running a 2560*1600 resolution (ignoring my secondary monitor, which I use when playing supreme Commander) and I like having anisotropic filtering at 16x and anti-aliasing at 8x or more. Quite a few games (e.g. UT3, Mass Effect) actually end up pushing GPUs with =<1GB and the framerate drops from 60+ to <20 when switching from 4x to 8x anti-aliasing.
  12. Redsnake77
    Redsnake77 Useless Idiot
    7 Jun 2009
    How about an overclock comparison between 5870 and 480?:naughty:
  13. Pete J
    28 Sep 2009
  14. H2O
    H2O Burnt Acrylic - Mmmmmm
    1 Aug 2009
    5850 CF here I come! :)
  15. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
  16. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    I feel justified with my purchase of a 5850. I bought it and woke up to find out that fermi was out and reviewed. Doesn't look like I'm missing much. Reminds me of the Fx years, performance is alright but not at that thermal load and wattage.
  17. brave758
    brave758 Minimodder
    16 Apr 2009
    All this bad press. Just remember what the ATI 2xxx was like when if first came out and look at it now. Given i was hoping from more from Nvidia how will this architecture fair with age maybe 18 months down the line, a die shrink or when the 40nm process is nailed will this card show its true colours.
    But for now i still have no reason to upgrade my CF 4870's....... Dam
  18. NuTech
    NuTech Minimodder
    18 Mar 2002
    How disappointing.
    Do you think we could get a Fermi based podcast with the Bit guys sounding off with their thoughts about the card and Nvidia in general? A few months ago Tim made some very interesting observations on the hardware podcast about Nvidia's increasing apathy in regards to the high-end graphics card market and their greater focus on embedded and mobile platforms.
    Would be interesting to hear more thoughts now that the NDA is lifted and Fermi has been benchmarked.
  19. ssj12
    ssj12 Minimodder
    12 Sep 2007
    i wonder how 3rd party non-reference cards will be.
  20. Pete J
    28 Sep 2009
    Nah, plenty of room and a perfect platform to fry a good sized steak.
Tags: Add Tags
