Hardware Nvidia GeForce GTX Titan X Review
Discussion in 'Article Discussion' started by Combatus, 17 Mar 2015.
  1. David
    7 Apr 2009
    So, your argument is that there's no difference between the 360 at (I assume) 1080p and a PC with the GTX 980 at 1440p, but you link to a 1080p youtube video comparison between consoles and start to change your tack to 360 vs XBone. In a GTX Titan X thread?
    :eyebrow:
  2. cps1974
    cps1974 What's a Dremel?
    29 Apr 2014
    and it would need to be located in lapland (or further north) for cooling!
  3. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Well, if I could find a comparison of the 360 and the PC I'd have posted it, but the point remains. They're effectively identical, and no, the extra (ha!) 360 lines of resolution don't make much difference.
    P
  4. David
    7 Apr 2009
    Oh well, if you say they're identical, it must be right. We'll take you at your word, won't bother to investigate further. Do you want to email nvidia and tell them to pack up shop, or shall I?
    Oh, and by the way, the extra (ha!) 360 lines of resolution equate to a increase in pixel count of 78% over 1080p. You do know that a standard 1440p display has more horizontal pixels too, right? :p
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Dammit, I knew I'd forget to change that first one! Thanks - will fix now.
  6. Dogbert666
    17 Jan 2010
    Also, UK pricing has now been confimed and it's even higher than I thought it would be. Titan X can be yours for the cool price of £879.99 - retailers should be taking pre-orders now, and I think stock will be arriving in a week or two at most.
  7. Guest-44432
    Guest-44432 Guest
    This was to be expected... 12GB VRAM is just not needed, let alone in 5yrs time.
    Still, 4K monitor to buy at the end of the month, and I might grab 2 of these if they have the same shelf life as the previous Titan. :)
  8. jinq-sea
    15 Oct 2012
    Quite steep, innit. It is a nice card though!
  9. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Well definitely staying the Sli route with the 970's. It's only a game card as well
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Scan are now taking pre-orders for between £880 & £935 depending on manufacturer.
    ETA varies between none, March 24 & April 1.
  11. Phil Rhodes
    27 Jul 2006
    I'm not sure what you're trying to imply here. I've played the PC version extensively and there's a lot of video of the 360 version and they look alarmingly similar. My query was what we'll end up with when people actually start mastering games to make full use of the capabilities of something like a GTX980. This is a fairly normal situation which happens more or less continuously as things improve - the high end of today is often poorly exercised by current games. It's not exactly a novel or controversial point to make, it just means that things like the reviewed card, while great, probably aren't all that worthwhile if you just want to play current games.
    I think the people who produced the game would be a better target - it looks to me to have been produced with the older generation in mind.
    Not that it looks terrible, or anything - and I suspect I'm getting it at rather higher frame rates than the 360 version, which is tricky to determine on youtube.
    P
  12. dolphie
    dolphie What's a Dremel?
    6 Jul 2012
    ^ All what you are talking about is more to do with it being a console game without much difference in the pc version. If you want to see a big benefit for your high end card, you need to be playing a PC game like Arma3 or something and something that benefits from high resolutions, like an MMO where the UI ends up out of the way.
    That said high end cards are only for people who can afford the best and don't care about price. Otherwise it is best to wait a while and then you get something similar or better for half the price. Look at the first Titan.
  13. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    True but besides the point. I'm simply impressed by Nvidia's GPU architecture. It's incredible.
  14. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    Titan X expensive? It's all relative.
    Cat poop coffee 1 Kg Filter Grind £297.00...3Kg £891, you can keep the coffee.
  15. theshadow2001
    3 May 2012
    That coffee can't even run crysis
  16. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    In order to assess the relative price of everything I tend to convert it into 'packets of cigarettes'. The average price of a packet of 20 cigarettes in the UK is £7,98. Hence the Titan X comes in at about 112 packs of cigarettes. That is, for the average smoker, less than four months of cigarettes.
    Quit now, have an SLI Titan setup by Christmas. :)
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    Neither can the Titan X, 25 FPS min in Crysis 3 at 4K...
  18. David
    7 Apr 2009
    I quit two years ago - I wonder if I can retrospectively justify it to the the missus..?
    I'll see you in the emergency ward.
  19. Kovoet
    26 Aug 2009
    My logic was I needed 2-970's to play the new games and also if one broke I'd have a spare one lol
  20. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    How about this one.
    Sorry about it being in Spanish.
Tags: Add Tags
