News Nvidia GTX 580 power limit bypassed
Discussion in 'Article Discussion' started by CardJoe, 15 Nov 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. PT88
    PT88 What's a Dremel?
    13 Apr 2009
    Time to turn on Overchrage on my Personal Nuclear Power Plant!
  3. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    +1 :D
  4. Zurechial
    Zurechial Elitist
    21 Mar 2007
    It's interesting to note that StarCraft 2 is far from the only game that exhibits that problem, so anyone using this should be wary. Many games lack framelimiting in the menus or loading screens (or any time when the game world is not being rendered).
    Crysis, for instance, doesn't seem to limit frames while in the menu or loading screens. I can see the framerate jumping up to just under 1000fps on my GTX275 at the menus in Crysis and all the way until it gets in-game. Not that I need to see it, as my GTX275 tends to capacitor-squeal when working like crazy.
    Many other games exhibit this behaviour, so players be warned - StarCraft 2 isn't the only game that could drive a GTX580 crazy with this hack. :)
  5. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Cue a malware writting ejit thinking wouldn't it be fun to write this into his latest trojan as a immediate executable when a gtx580 is detected!
  6. Paradigm Shifter
    10 May 2006
    As you say, Zurechial, Starcraft 2 isn't the only game that causes the GPUs to 'overwork' in menus - Magic: the Gathering: Duels of the Planeswalkers does the same if Vsync is disabled. I imagine lots of others do, too, but I tend to run with Vsync forced on, as tearing (even a little bit) drives me up the wall...
  7. GoodBytes
    20 Jan 2007
    Batman AA is another game that uses no frame limiter in the menu or pause screen.
    Notice how your GPU fan spins like no tomorrow in the menu or when you pause the game, while in the game, where you would think you stress the GPU, the fan is fairly quiet in comparison.
  8. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Nobody else noticed this is comfortably outside ATX spec?
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    Can we tweak it so it'll go to say, 300W?
  10. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    So what exactly does this thing do? It just limits the maximum power draw? Is there any performance gain to be had? And how will you supply a card with 350 Watt?! PCI-E slots give you75 Watt, each 8-pin connector another 150. That adds up to 375... pretty close if you ask me. Unless they added a 3rd 8-pin that I missed.
  11. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    <-------'Going out to get marshmallows'
  12. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    As the article says, there's no benefit to this modification with real-life usage, only with benchmarks. It could be useful with OCing, but you would risk burning out the card/mainboard any time you hit something like that non-framerate limited menu of SC2 :)
  13. fingerbob69
    5 Jul 2009
    hasn't that been patched yet?
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    150w + 75w + 75w
    8pin + 6 pin + pcie slot
    you'd think something gotta give- water cooling at 350w would probably be a good idea to keep temps down on the gpu
  15. Cool_CR
    Cool_CR What's a Dremel?
    3 Oct 2009
    Hard core but i can see somevery sad people if this start fragging motherboards and tripping out PSU's.
  16. wyx087
    wyx087 Multimodder
    15 Aug 2007
    it's like those 150mph limiters on modern saloons, why would you want to take it off if you are not going to take it on the tracks?
    allowing it is just dangerous, it should only be done by reviewers and extreme overclockers, normal users should not be allowed to have such simple tool.
  17. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I, for one, cannot wait for the GTX 595, with it's "Conservative" 400W limiter, and 6 8-Pin PCI-E connectors.
  18. GoodBytes
    20 Jan 2007
    You mean a 24pin motherboard connector :)
  19. Anakha
    Anakha Minimodder
    6 Sep 2002
    Yes. See that wonderful little checkbox labelled "VSync"? Click that and the problems are gone forever.
  20. Tulatin
    16 Oct 2003
    Anakha, games should not need to limit their needs to account for poorly designed, power hungry chips.
Tags: Add Tags
