Hardware Nvidia Hybrid SLI follow up
Discussion in 'Article Discussion' started by Tim S, 22 Jan 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. naokaji
    naokaji whatever
    8 Dec 2006
    could it be that there is only one display supported because sli doesnt support more than one either? just a thought.
    anyway, good article on a technology that sure looks promising (even though it needs some refining).
  3. Tim S
    Tim S OG
    8 Nov 2001
    Nope, there is support for two displays... but only one can be digital at the moment because of the hardware limitations.
    Nvidia is also working on multi-monitors for SLI too (Hybrid SLI will get that from the outset)
  4. Darkedge
    Darkedge Minimodder
    26 Nov 2004
    so still basically for first iteration avoid. I mean don't touch with 50ft bargepole.
    I think all this could be done on graphics card and Nvidia as usual have gone for the expensive for customers, easy for them route which means buy new hardware for dubious results. Willing to give it time but even telling people now about what seems a fundamentally broken system seems pointless
  5. naokaji
    naokaji whatever
    8 Dec 2006
    the way they are doing it you need both, a nvidia graphicscard and a nvidia mainboard for it to work, if they would have included a secondary weak gpu on the graphicscard for it you would only need to buy a graphicscard for it.
  6. zoom314
    zoom314 Minimodder
    10 Jun 2003
    I'll have to remember that barge pole as I travel along the ole Erie Canal one day. ;) But yeah, It needs development still in the 2560x1600 and display port res department. :D
  7. completemadness
    completemadness What's a Dremel?
    11 May 2007
    Well personally, i'm not at all enthused by this, However, it is early days, and there are many bugs to work out
    Also, i note nvidia have been quiet on the XP front - again
  8. Tim S
    Tim S OG
    8 Nov 2001
    I think it's limited to Vista because of the way it handles video memory in scenarios like this. It's definitely not limited to SP1 though - that's one thing I asked.
  9. dmak
    dmak What's a Dremel?
    1 Apr 2006
    when they impliment displayport, doesnt that meet multi display will be easier? I thought displayport supported daisy chaining of monitors... or maybe that wa a future project. oh well
  10. Tim S
    Tim S OG
    8 Nov 2001
    Yep, that's definitely within DisplayPort's remit, although I would imagine that you'll again be bandwidth limited when it comes to the resolution/number of monitors you can daisy chain.
  11. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    How does daisy chaining the monitors work?
    p.m me to keep thread clean :D
  12. Tim S
    Tim S OG
    8 Nov 2001
Tags: Add Tags
