Blogs Nvidia Ion 2 details, or so we think
Discussion in 'Article Discussion' started by Sifter3000, 15 Feb 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. darklord of chaos
    darklord of chaos What's a Dremel?
    23 Jan 2007
    hmmm, not really too bothered about graphics but as for the sata ports I would like to see more than 4 which is all i seen on the original Ion platform the pci slot on the olivemount boards is dual riser compatible which would allow me to use two 4 port sata2 card ( 3 internal 1 ext ) from lindy.
  3. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    If Ion2 uses other CPU's (VIA's Nano 3000 series for example) then I might show interest, but if it's limited to Intel Atom hardware, then I couldn't care less.
  4. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    is there any need for Ion to be more powerful? It can play back HD movies as is, and is too CPU limited for most games.
    More "other things" is what it needs, but as you say it could be challenging to implement more SATA ports, Gigabit ethernet and the like.
Tags: Add Tags
