News Nvidia launches GPGPU investment scheme
Discussion in 'Article Discussion' started by CardJoe, 17 Mar 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Someone's trying to push their technology...
    Not a bad thing though. Badaboom for example is awesome for video encoding. Let's see what else is coming.
  3. s3v3n
    s3v3n MMO Cold Turkey -fail
    23 Jun 2008
    Don't know if they've updated Badaboom but I tried the program about 2 months back and the lowest bitrate was like 500kbps, which to me is just a waste of space. I'm assuming most people are encoding to play the videos on their portable media device with a screen of like 320x240, which only need like 200kbps. Hell, my encodes for my PSP at 480x272 only needs 250kbps and still get a good picture quality.
  4. perplekks45
    9 May 2004
    Waste of space? Well, maybe but if you re-encode videos in HD there's just nothing that matches the speed of Badaboom.
  5. wyx087
    15 Aug 2007
    that's good news, at least for nVidia users.
    but without opening up their platform, it's never going to take off.
  6. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    If it does take off do you think AMD will finally give in and pay the licensing fee to run it on their hardware?
    Just bought a 4870 1gb :p
  7. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Is this Nvidia's attempt to combat OpenCL? I'm sure the financial incentive is good, but wouldn't it make more sense to develop apps that target the widest possible user base?
  8. Saivert
    Saivert Minimodder
    26 Mar 2005
    OpenCL isn't the only API. You got DirectX 11 Compute Shaders coming as well.
    Besides NVIDIA has a good working solution for GPGPU that you can use now.
    I don't see anything from OpenCL yet. It's just a spec atm.
  9. Sebbo
    Sebbo What's a Dremel?
    28 May 2006
    according to the Register, to receive the funding the product doesn't even need to be CUDA based, or run solely on nvidia hardware.
    what i find slightly dubious however, is that what you submit to nvidia is basically going to be non-confidential, so unless you have patents etc guarding your ideas, what's to stop them from taking an idea and running with it, especially if they have more resources than you? "Trust" isn't a very good safety line
Tags: Add Tags
