Case Mod - In Progress Nvidia li
Discussion in 'Project Logs' started by nightmare-mike, 10 Aug 2009.
  1. nightmare-mike
    nightmare-mike sry for my english, i'm dutch
    10 Aug 2009
    hello guys,
    i'm new at the bit-tech forums.
    excuse me for my bad english i'm just 15 :D
    i would like to show my current casemod.
    the case i'm using for this casemod is a lian li pc 7-f:
    some of the components i'm using:
    - asus P6T;
    - core i7 920;
    - asus GTX 275;
    - OCZ 6gb ddr3-1600;
    - 2X hitachi 500Gb HDD;
    - cooler master 850w psu
    i've beeen modding it for like 2-3 months now so i'll show you guys the progress i've made.
    first of al i cut a window in the sidepanel of the case:
    then i mounted some plexi on it with these little things:
    i put some 2 components glue on it and let it dry:
    then i mounted the plexi with screws so i can take it off later on:
    the result of it:
    then it was time for some soldering.
    i wanted every fan and led to be green.
    so i started of with the power and HDD led:
    then i modded my front fan to.
    didn't want to buy another fan just for the green leds so i did it myself.
    before:
    removed the old leds:
    new leds:
    result:
    i'll be using a couple of switches on the back so i can switch the leds on and off.
    the day after i desided to stealth the DVD player.
    first of all i didn't want anything to stick out so i rerouted the switches:
    the reset button will (is) acting as the open/close button.
    the stealthing itself:
    breaking of a front bay:
    and done:
    i put some 5% foil over the plexi so it wil act as a 2-way mirror:
    result without light:
    and with:
    getting kinda tired of copying and pasting.
    so will do another update later.
    mike
  2. maRiio
    maRiio What's a Dremel?
    27 Jul 2009
    I love those two-way-mirros.
    Good choice of the case, hope you keep it that clean :thumb:
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Sellotape cheesecake! It's all that's holding the front on one of my cases atm.
  4. stonedsurd
    11 Mar 2009
    1. What'd you cut the window with? Mighty clean job.
    2. The 5% film - is that the stuff that goes on car windows?
  5. maRiio
    27 Jul 2009
    i would say YES :D
  6. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Black and green. loving it!!!!!!!!!!
  7. nightmare-mike
    10 Aug 2009
    thanx guys.
    and yes it's the stuff that goes on cars :p
    i bought the plexiglas from a special store, i like the quality of it ;)
    i cut the window first a bit with dremel then further with a jigsaw.
    i fked up but managed to make it ok with a little help of my granddad :D
    sorry for not responding in a while :S
    i'll post an update of more i've done the past weeks.
    mike
  8. stuartwood89
    20 Aug 2008
    I love clean mods like this. I love what you did with the fans.
  9. nightmare-mike
    10 Aug 2009
    update
    ok like i said sorry for not responding.
    i'll be rresponding quicker now i know my topic is placed ;)
    so now time for the update:
    some of the cables for the DVD drive
    some thing i ordered for the case:
    decided just to use the lian li fan:
    removing the fan itself:
    drilling holes for the LEDs:
    i put 4 3mm green LEDs in there:
    result:
    i know it looks kinda like the sign of hitler :duh:
    and in the case:
    disassembled my cooler master 850w psu:
    and took out the 140mm fan:
    i noticed there were pre drilled holes in it:
    so i put some LEDs in there and here is the result:
    next up the component i got:
    OCZ platinum 1600MHz ddr3 mem:
    asus P6T:
    and ofcourse the core i7 920:
    everything together:
    and in the case:
    decided to paint the stupid red SATA cables black:
    when i wanted to put the sidepanel back on i saw the fan was blocking the sidepanel:
    so i cut a little bit out:dremel::
    made it nice and smooth again:
    now it fits:
    here you see the case without the CCFL's on:
    and you can see me :D
    and with the CCFL's:
    installed windows 7 RC on it:
    and my nice momentary mouse:D:
    [​IMG].
    will do another update later to where i am right now.
    mike
  10. nightmare-mike
    10 Aug 2009
    thanx,
    when my update get approved you'll see more fans you'll like :D
  11. wbdog206
    wbdog206 not me
    15 Jan 2007
    +1:thumb:
  12. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    W00t, nice project. Did you ever looked at nanoxia fans? They are real nice!
  13. nightmare-mike
    10 Aug 2009
    yeah i know the nanoxia fans.
    they are really rare where I live so I improvised a little bit.
    it should be in my update.
    still no sign of my update:wallbash:
    edit:
    you know they are rare cuz your dutch too.
    maybe you can get them in germany but it's diffrent for me :(
    doesn't matter i got my own nice fans :D
  14. Sni9er
    Sni9er Ermmmm 42 ???
    16 Apr 2009
    nice use of lighting i love that plexi and film you have used, also your home made led fans are a great piece !
  15. nightmare-mike
    10 Aug 2009
    thanks ;D
    i'll do an update today to the point i am right now.
  16. nightmare-mike
    10 Aug 2009
    update
    hey guys,
    after this update every new update is about what i did that day.
    so here's my last long update:
    i got some stuff i ordered:
    this package includes: wires, resistors, and some switches.
    I made a PCI slot into a switch panel:
    soldered it all up:
    and put it in the case:
    now i had to do all the wiring for the leds and CCFL's:
    here's how it works:
    switch 1: UV CCFL's
    switch 2: green CCFL's
    switch 3: front fan leds
    switch 4: PSU fan leds
    switch 5: rear fan leds
    here's a picture of my case with only the leds on:
    here some more pica's i made with lights on and off:
    so let's get on with some other things.
    didn't like the fact my G15 was green so i got my green module i modded for my other G15 wich died later on :(.
    here's the G15 with the module in the front:
    disassembling the G15:
    replacing the leds:
    testing:
    and it's done:
    also got a new toy:
    in comparisson to my old card:
    and installed into the case:
    did some benching ofcourse.
    3dmark 06:
    look at my CPU wich is a core i7 920 not 975 like it says.
    3dmark vantage:
    not the best scores but it's all stock.
    i'll post my next update when I modden my graphics card.
    i want to put Uv green plexi on it and dremel the Nvidia logo in it.
    mike
  17. maRiio
    27 Jul 2009
    nice work ;)
    the keyboard looks great but i think the blue display won't be that good looking anymore imho.
  18. Kyor
    Kyor A Visitor
    28 Jul 2009
  19. nightmare-mike
    10 Aug 2009
    thanks,
    i still want to change teh color of the display.
    but there aren't any leds or SMD's in there.
    maybe i'll put some green foil in front of it so it will be a little bit greenish.
    and I know It-service.be ;)
    nice online shop but I won't be needing those nanoxia fans anymore now i moddded my own.
    they were my first choice before i modded the fans.
    I still want to get my watercooling at it-service.
    but first I need some money ;)
    mike
  20. Kyor
    Kyor A Visitor
    28 Jul 2009
    hehehe i know the feeling, i'm currently planning my mod to and after a few calculation... lets just say i got a smack in the face :p
