Hardware Nvidia Optimus: More Than Meets The Eye
Discussion in 'Article Discussion' started by Sifter3000, 9 Feb 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Baz
    Baz I work for Corsair
    13 Jan 2005
    Graphics cards in disguise...
  3. Toka
    Toka Minimodder
    19 Nov 2006
    *head desk*
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    Tho it seems interesting, if I use VLC to render video in D3D or OpenGL, if it's a 420p video, I'm pretty sure I don't need the extra oomph to render it, so I guess the best solution would be a mix of "autobotonomously" and a switcheroo.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    If it ends up working as advertised then it will definitly be a great thing, but after how much trouble the previous solutions where I'm just a bit sceptical.
  6. batfink
    batfink What's a Dremel?
    5 Nov 2009
    x2
    Rich, you should be ashamed. That is DREADFUL.
  7. Toka
    Toka Minimodder
    19 Nov 2006
    It was wonderful!
  8. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    I'm pretty sure the Nvidia graphics in my unibody MacBook Pro have done this for some time? Switching between the integrated 9400M and the discrete 9600M GPU's as and when necessary?
  9. SubtleOne
    SubtleOne What's a Dremel?
    21 Nov 2007
    If they combine that with the external GPU concept, they will really have a huge winner. The inherent limitations of high-level internal GPUs are too many at the moment: space, heat, power consumption, speed that quickly becomes very dated, and insane pricetags that are usually *completely* out of proportion with the desktop equivalents.
    Imagine being able to take your notebook, with decent CPU and Ram, but typical integrated graphics, and being able to not only hook up an external gaming GPU, which could be upgraded without needing to buy a whole new machine, and also benefit from the Optimus technology. That would be sweet.
  10. dec
    dec [blank space]
    10 Jan 2009
    Yea ill bring my laptop and a GTX280 to LAN parties :lol:
  11. DbD
    DbD Minimodder
    13 Dec 2007
    Seems like a source of unreliability to me - I'd just want to run with nvidia all the time - the nvidia card should just have a low power idle state removing the need any onboard graphics. However I can see why they are doing it - now they can't provide chipsets for iWhatever due to intel's bullying they need another way in. This keeps intel happy, while allowing nvidia a way in to sell stuff - very smart way to make money despite the chipset lockout.
  12. mi1ez
    mi1ez Modder
    11 Jun 2009
    [quotemsg]we have no doubt Nvidia has its Optimus primed to create a considerable shockwave in the industry.[/quotemsg]
    TWO references in one sentence? Really?
  13. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    On it's own, it's hardly new or all that exciting, but if the use of Optimus Technology becomes part and parcel of external laptop GPU's then this will truly shine. Within existing constraints for laptop graphics, those with non-gaming laptops will have a feature that they will not truly appreciate.
  14. Sifter3000
    11 Jul 2006
    If bit-tech was an Xbox game, you'd get an achievement for spotting all the references in this article :p
  15. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    If I find them all do I get a gold or a platinum trophy?
  16. Sifter3000
    11 Jul 2006
    It would be made of unobtanium.
  17. wyx087
    wyx087 Multimodder
    15 Aug 2007
    seems like a software solution that they piggybacks through Intel IGP.
    hope to see this in H55/H57 platforms for some GPU down-time.
  18. idontwannaknow
    idontwannaknow What's a Dremel?
    20 Feb 2009
    Um, the 3dfx Voodoo2 worked exactly the same way as this... it just used an external VGA pass-through cable to do it.
  19. TESCO-Zsömle
    TESCO-Zsömle What's a Dremel?
    28 Jun 2008
    When I first saw this, just think: BEWARE! Here comes the mighty Marketing ******** Monsta... And yeah! (Sh)it happens...
    Very old(, long forgotten) tech, and now it's reinvented again...
  20. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    I'm guessing ATI are not invited to the nvidia/intel party then ?
Tags: Add Tags
