News NVIDIA orders 80nm G80s
Discussion in 'Article Discussion' started by Da Dego, 16 Jan 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. DougEdey
    5 Jul 2005
    Finally! Will it go below 185W?
  3. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    Die shrink is always good, with this and PCIe 2.0 at about the same time, we may finally be able to loose those power connectors, which in turn means less damned power regulation circuitry on the card, which means we might be able to fit the damned things inside a case!
    Look at the current VAT free prices if you want an indication od the price drops we can expect and it isn't likely to be far wrong imo.
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i am waiting for the 8600..... cheaper and DX10 and it is powerful....
  5. Lonesarah
    Lonesarah What's a Dremel?
    6 May 2006
    Probably not, Knowing nvidia they will find a way to **** things up.
    Can I say ****?
    P.S. I'm back from being ban for a year.
  6. poenanie
    poenanie What's a Dremel?
    9 Jan 2007
    that's good news :)
  7. EQC
    EQC What's a Dremel?
    23 Mar 2006
    Hmmm...when you say that, I hope you remember to group NVidia and ATI (or, the ATI branch of AMD) in that same group. IIRC, rumor has it that ATI's R600 GPU is going to debut with a power draw even higher than NVidia's regular 8800GTX.
    I don't think either GPU company intends to work too hard on meeting lower power requirements any time soon...
    PS: welcome back from your ban...based on your use of ****'s, I'm guessing you were banned for language?
  8. DXR_13KE
    14 Sep 2005
  9. BFGunrunner
    BFGunrunner What's a Dremel?
    13 Mar 2006
    lol
    Anyway I'm thinking the 80nm versions of the G80 is going to be the G81's or 8900's
  10. DXR_13KE
    14 Sep 2005
    and 8600
  11. poenanie
    9 Jan 2007
    I hope so , that way i can immediatly buy one of those :D
    Otherwise it'l be like when i had mt 7800 and the 7900 came out , i just had to have one :p
  12. Lonesarah
    6 May 2006
    I know someone would miss me.
    It's rumor that the r600 has an updated frame buffer, that's include into the xbox 360 gpu.
  13. DXR_13KE
    14 Sep 2005
    from now on please behave and obey the moderators.
  14. mmorgue
    mmorgue What's a Dremel?
    16 Feb 2005
    I really don't think you can point the finger at Nvidia only. As mentioned above, ATI are just as guilty of upping the power reqs of gpu's to extraordinary levels.
    I mean, we now have 2000 watt power supplies! Madness... running two machines are home and a laptop, I have noticed my electric bills higher this year than last.
    /sigh -- I want mini components, not massive!
  15. Tim S
    Tim S OG
    8 Nov 2001
    the price of fuel has gone up, though (at least in the UK)
  16. DougEdey
    5 Jul 2005
    The price of oil is rising to $50 a barrel soon, it's a psychological price point however, it's relatively fine with inflation.
    Not sure why that has anything todo with power consumption though Tim?
  17. mclean007
    mclean007 Officious Bystander
    22 May 2003
    I think his point was that the rising fuel prices at domestic supply level mean that, even if your consumption remains static, you will see an increase in the bill, which may go some way to explaining mmorgue's situation - it isn't just that he's using more power, the power he uses is also more expensive.
    Interestingly, although domestic prices have shot through the roof, oil prices have actually dipped recently. We should see a knock-on in a few months, because suppliers buy their stock on the wholesale market in blocks a fair few months in advance.
  18. DougEdey
    5 Jul 2005
    But even though fuel prices have gone up, using 185W compared to the old values is going to hurt a lot more.
  19. mclean007
    22 May 2003
    True, but remember 185W is the absolute max power draw of an 8800GTX at stock speeds. In normal Windows use it won't be using anything like that, and even while gaming it will only be if you really stress the card that it will hit its peak. 1 kWh at the moment maybe costs 15p tops, so running a PC that eats say 1/3 of a kilowatt will cost you 5p an hour - not bad value for your gaming entertainment fun IMHO. Even a total beast of an overclocked PC will struggle to burn through 500 Watts on average while gaming, so even that is just 7.5p per hour.
  20. DougEdey
    5 Jul 2005
    Why are they producing such massive power supplies if there's no demand for it? If 2KW PSUs weren't required for some systems there would be 0 need for them and they wouldn't be made.
Tags: Add Tags
